Adaptive Cruise Control not working in cold weather
Hello,
I was wondering if anyone with ACC has experienced this. I noticed my ACC would be down during cold weather and during warmer days would be active. We had an unseasonably warm day yesterday in the east coast and it was working fine. Today it was back in the 30s and it wouldn't work. By the way, I don't get any error message in the dash such as "ACC not working." Where in the system would the problem be and how to fix it (is it a matter of insulating the wires? ) I do have some holes in my underbelly panels by my front doors due to winter weather driving, not sure if the ACC wires go through there. Thanks in advance! |
Any salt/dirt covering sensor?
Originally Posted by goodoldsequoia
(Post 25681597)
ACC uses more sensors than the ones on front bumper, try to clean every sensor which looks a like a coin size, on both sides and rear. Any one sensor blocked, it "refused" to do ACC for you. Can you provide a pic of underbelly panel? I don't think anything inside the car will prevent the ACC from working properly though.
(Post 25681609)
https://cimg7.ibsrv.net/gimg/www.aud...5b0a39eb8e.jpg |
Never looked at what's behind that panel but I will say very unlikely wires went through there.
Are you sure the ACC problem is ONLY related to weather/temperature? |
So, I have a MY 2012 and one of my two sensors has failed and rendered ACC inoperable. Even though there will not be a message telling you so, if you use VagCom, you'll see the errors there. It'll even tell you which is the offending sensor.
I tried all the obvious things (cleaning the dome sensor, cleaning and reseating the connector, giving it a light tap or two) but it still does not work. The unit operated and failed intermittently for around 4 months before finally failing permanently but my experience was opposite of yours. Only on long drives (2+ hours) would it fail when engine temps had saturated the entire front of the vehicle with warmth. I'll be taking the sealed unit out this weekend and opening it to see if I notice anything obvious (like a failed seal) or any corrosion. I'll bathe the internals in electrical cleaner, let it dry out and then try again. This is a last-gasp effort, of course as the sealed unit is not user serviceable. A new replacement is over $4K and used units are less but risky. And, then, you have to take it to the dealer to have it coded to your vehicle (yes, it's a coded part) and then calibrated. It will not work otherwise and I have yet to find an indy shop that has the tooling to do it. I'll let you know how it goes here next week sometime. Edited to add: temp fluctuations are a common early instigator of electrical component failure. The heating and cooling expands and contracts the various circuit board materials and bi-metallics at different rates causing cracks and separations at the component level. Typically, when you see temp-related intermittent failures like this, it is signaling the death-throws of the device. |
Good luck , man. Wish you luck and update us here. I know I will be there not too many years from now even though it's 2021. It didn't work right from day 1.
What a German engineering... I thought German is only not good at software stuff but I was so wrong. My 2021 gas pump seal broken at 7 months by itself, no crash or bump to the car, garage kept. Only 1600 miles!! |
(Post 25683087)
What a German engineering... I thought German is only not good at software stuff but I was so wrong. My 2021 gas pump seal broken at 7 months by itself, no crash or bump to the car, garage kept. Only 1600 miles!! I can't feel bad about this radar sensor failing. My car was a first gen 2012 C7, picked up in October 2011 and it has 160,000 miles on it. I mentioned elsewhere on these forums that my total outlay for repairs that were not maintenance or normal wear-and-tear (like brakes or filters) was less than $4k for the life of the car. $4k for 10 1/3 years. It's been spectacular. |
(Post 25683063)
