Apple CarPlay retrofit for C7 A6 (pre facelift) - any recommendations?
#11
PM was sent with my email address.
If the steering wheel buttons don’t interface with the CarPlay box, is there a way to call up Siri (other than pressing the home button on the phone)?
#12
@cccjrsbox I'm not necessarily a "fanboy" but I do live in the ecosystem for sure. I had a crappy rental Malibu that had CarPlay and as much as I hated the car, I loved CarPlay. Does the $280 kit come with everything you need part-wise to accomplish the install? I've read a bit about the VIM, do I need to purchase anything to work with that too? (PS- I really appreciate the help!)
#13
Its installed in my car. These instructions helped, but you'll need a little common sense too: Example
Thanks for sharing your knowledge!
#14
I imagine "Hey Siri" would work assuming your phone can hear you?
Everything was included (except for the VCDS cable of course). One of the cables sent in the kit didn't plug in correctly, had to use an exacto blade to shave some plastic - then it locked in great.
I didn't have to enable video-in-motion, but did need to enable aux audio. Used a VCDS cable and vag-com software from Ross Tech for that. Might be able to use another tool I've seen around here - ODB11 I think. VCDS was more familiar to me though - I had already used it to enable a bunch of other features like needle sweep, windows up with remote, rear DRL's, etc.
One more thing - support from the seller is pretty crappy, big language barrier and several days between question/response emails. Luckily I figured out my own answers while waiting for a response. I had asked them about the misfit cables, and how to enable the unit (I had been trying to use the nav button on the steering wheel instead of the nav button on the mmi). I figured both of these out though. Other than those hiccups, it was really straight-forward.
#15
Did you install the CarPlay unit behind the panel under the steering wheel, or did you find room behind the CD player or HVAC? Also, did you run the USB cable to the storage bin in front of the shifter, or did you go back to the armrest?
#16
@cccjrsbox, I really appreciate all your help. I’m looking forward to doing this mod. Maybe I’ll order the CarPlay adapter before this weekend.
#17
#18
@ccjrsbox - I've been reading and researching this quite a bit... and emailing the retrofit manufacturer too. One thing I'm not seeing is how the usb connection is handled. I'm assuming it's not through the AMI port since any newer iPhone won't work. I'm not wanting to have some random USB cable emerging from my car in an unnatural place. How is yours handled?
#19
Hmmm, I guess you already answered this a bit above. I've love my usb->lightning cable to be mostly hidden - if not completely hidden. That's one thing I love about the AMI port (the only thing really). I can put my phone under the armrest and hide everything. Is that even a remote possibility?
#20
I agree that under the armrest would be ideal, but my chances of getting a Saturday to myself around here to tinker are slim. Kids are way too busy and kitchen passes are hard to come by!
