Audi Drive Select
#21
Plus driving through the mountains of Colorado using the paddle shifters is just a TON of fun. For context, my A4 was a manual... I do miss the manual sometimes... nothing like a little heel/toe work. But the A6 more than makes up for it with power, being smooth, and comfortable for 4. Our last trip up the mountain I had a 6'3" guy in the back seat - and he claimed to be comfortable! I couldnt have gotten him into the A4 without a shoehorn.
#22
I have additional questions re: the Drive Select System. Is the default setting the same as Auto? Does your settings revert back to the last used setting every time you start the car? I was just wondering because mine seems to be on "default" setting and won't remember the last used setting. Thanks
#23
#24
I did mention mine doesn't do this. It does not remember the last used ADS setting I picked. So if I picked Dynamic, parked for the night, it goes back to "default". Is this a problem with the MMI software, or is this exclusive to engine/transmission choice? I have the 2.0T CVT version.
#25
Get everything set the way you like it. Seats, mirrors, drive select. Use the set button on the door to store your settings. Exit the car, lock the door with your key.
I believe it will remember your drive select on the next try....
jc
#26
Thanks for the response MileHighJC. I tried it and it wouldn't work. It does remember the seat setting and mirrors but doesn't remember the ADS. I intentionally picked Dynamic as you can see the symbol S>D on the dash to determine it's dynamic. It goes back to default. Unless there's something I didn't think of...
#27
#28
Seatbelt - Dynamic
Suspension - Dynamic
Engine/trans - Auto
#29
I think the issue may be that the dash display doesn't show the "S" indicator if you have the engine set to dynamic mode in the MMI, only if you use the shift handle to switch to "S" mode(?).
I have a 2013 and it remembers that I leave it on dynamic for all settings on the MMI every time I get in the car. But it does NOT show the "S" on my dash display.
Maybe somebody else can confirm this... does the "S" indicator always show up if you're in dynamic mode?
#30
