Brake Pad change help please
Old 04-21-2017, 06:40 AM
  #11
snagitseven's Avatar
Originally Posted by dc2002
Fronts "typically" wear out before rears...i have seen 2X the mileage on rears vs fronts on past audis & vws
I used to believe that too. I've been proven wrong as the rears usually do wear out faster than the fronts on the A6. This is true especially with ACC and the Presense Braking Guard which mostly use the rear brakes to slow or stop.
Old 04-21-2017, 08:13 AM
  #12
tenspeed's Avatar
Originally Posted by konijay
"Brake Pads" light came on yesterday for me as well...
Does it say anywhere which is bad? front or back?
There isn't any place that says which pad is worn. The sensors are on the inside pads, front and back, drivers side. In my case, the rear pads were worn the most. I'm the second owner and rarely use cruise control so I expect my front pads to be worn more at the next service.
My new pads were 13 mm thick and the sensor comes on at ~3 mm so you have some time to decide what to do.
This is the gap on the front caliper with new pads.
Dr.Aronis
Q7 MK 1 Discussion
11-01-2018 01:48 PM
makav3li
Brakes Discussion
01-02-2012 05:56 AM
1st car in my name
07-09-2007 05:59 PM
tjolson19
Rocky Mountain Discussion
10
02-12-2007 04:16 PM
S4_Cinci (I S'edTFA)
12
01-24-2006 11:02 AM
Quick Reply: Brake Pad change help please
