Buzzing center dash speaker (2012 A6, bose system)
#32
Location under you logon name allows you and readers to have a perspective on your questions and answers.
#33
Or, I have a UPS account and can provide a label. In that case I would be willing to do $15.
#34
I realize this is an old thread, but wanted to thank the OP!! The Kenwood worked on my 2012 A7. It was a little deeper than the Bose so the installer had to make a quick cut to accommodate. I paid $29 for the pair of Kenwood and $48 for installation for a total of $77+ tax. Dealer wanted $450 to install the inferior Bose.
Thank you OP!
Thank you OP!
#37
#38
Thanks for posting this information. I miss this thread when it first came out. My center speaker does home or buzz when playing AM radio or certain tones. I always figured it was because I played it very loud and simply blew the center speaker. Nice to know there is a potential fix that's relatively cheap. Will check that out, and thanks for posting the DIY.
#39
I went to Crutchfield's site and Rockford Fosgate P132 speaker is actually listed as a fit for Audi Bose center channel. It is 3.5" vs 4" for the Kenwood. In comparing the specs the Sensitivity is lower at 85db which means it will be quieter than people have said of the Kenwood which is rated higher at 88db sensitivity. I have listed both specs below. Let me know what you all think. I'm planning to order one soon.Punch Series 3-1/2" 2-way car speakers
Specifications
Sensitivity (1W at 1 meter) - 85
Sensitivity at 2.83 volts - N/A
Frequency Response 120 - 22k Hz
Minimum RMS Wattage 6
Maximum RMS Wattage 20
Peak Power Handling (Watts) 40
Top-mount Depth (Inches) 1 1/2
Bottom-mount Depth (Inches) 1 3/4
Cutout Diameter or Length (inches) 3 1/8
Compared to4" 2-way car speakers
Specifications
Sensitivity (1W at 1 meter) 88
Sensitivity at 2.83 volts N/A
Frequency Response 50 - 22k Hz
Minimum RMS Wattage ---
Maximum RMS Wattage 21
Peak Power Handling (Watts) 220
Top-mount Depth (Inches) 1 11/16
Bottom-mount Depth (Inches) N/A
Cutout Diameter or Length (inches) 3 11/16
https://www.crutchfield.com/p_575P13...gate-P132.html
SpecificationsSensitivity (1W at 1 meter) - 85
Compared to
Kenwood KFC-1066S
https://www.crutchfield.com/p_113106...KFC-1066S.html
SpecificationsSensitivity (1W at 1 meter) 88
#40
I went to Crutchfield's site and Rockford Fosgate P132 speaker is actually listed as a fit for Audi Bose center channel. It is 3.5" vs 4" for the Kenwood. In comparing the specs the Sensitivity is lower at 85db which means it will be quieter than people have said of the Kenwood which is rated higher at 88db sensitivity. I have listed both specs below. Let me know what you all think. I'm planning to order one soon.Rockford Fosgate P132
Specifications
Compared toKenwood KFC-1066S
Specifications
Specifications
Specifications
