Center speaker
Old 07-19-2017, 08:03 PM
kevrhof's Avatar
Default Center speaker
How do you remove the cover for the center speaker under the windshield?
Old 07-19-2017, 10:14 PM
RazvaNNN's Avatar
there are no screws. just open it gently with something sharp (i did it with a butter knife)
Old 07-20-2017, 05:53 PM
AMDG75's Avatar
if planning to remove the speaker, you will need a 5.5 mm ratchet socket
Old 07-20-2017, 08:27 PM
dkp993-A6's Avatar
If your chasing down the rattle it's the speaker. Pretty common issues with the Bose system. There's a thread here that discusses it and gives options for speaker replacement.
Old 07-25-2017, 09:13 AM
kevrhof's Avatar
Yea I do have the Bose and I saw that thread but I honestly think mine is more of the cover itself. On certain phone calls it makes a crackle / rattle noise and if I put my hand on the cover it goes away. Similar to the rear shelf (which has a folded up piece of paper wedged in like an old dodge)
Old 07-31-2017, 02:10 PM
Vodka G's Avatar
yeah I replaced the center speaker with some 40 bux a pair Kenwood which is still better than the POS-E system :-)
if anyone need a single speaker to replace the center msg me
Old 08-07-2017, 01:55 PM
joebird's Avatar
I thought I had a speaker rattle -- turned out it was my HUD unit, which there's a known issue with.
Old 08-07-2017, 03:22 PM
porksoda's Avatar
how did you fix it?
Old 08-10-2017, 02:10 PM
joebird's Avatar
Originally Posted by porksoda
how did you fix it?
Technically it's still not fixed. I've had them try and fix it twice. The 2nd time they mentioned a TSB, which really just has them add some dampening material in there.
This has helped some...but is still an issue on a rough road. With the radio volume down, it's clearly more noticeable.
I eventually figured this out (vs. thinking it was the center speaker) when a friend in the passenger seat pushed down on an edge of the reflective material inside the HUD while driving. This stopped the rattle immediately.
Old 08-10-2017, 04:43 PM
DanfZX14's Avatar
Sounds to me like you need an audio system upgrade to permanently resolve the problem!
but that's just me.................
Quick Reply: Center speaker
