DIY Brake Pads and Rotors 3.0T
#11
Does it also say to replace the brake pad pins (front) and brake pad bots (rear)? Not talking about the carrier bolts at the 196nm. They are not removed on the rear.
#12
My rear pads (ceramic Posi-quiet) came with hardware including a pair of rear guide pin bolts.
#13
Honestly, I feel no difference between stock rotors and the EBCs. I bought them primarily for the looks. The cost is similar if not cheaper than the discounted OEM prices from places like genuineaudiparts.com. I think the pad selection plays a bigger role in feel and performance than rotors (under normal driving conditions anyway).
I went with Akebono pads...they are great on any rotor IMO. They do not feel as responsive as OEM pads but the difference is insignificant and the dust and squealing issues with OEM pads are virtually non-existent.
Invoice below...you can probably get them even cheaper if you catch them on sale or find a promo code. Again, the only catch is that you may or may not be waiting a while for the rotors so order a couple months in advance if you go through placeforbrakes.com.
It's been a great +1 upgrade for less than OEM replacements. The techs at my local dealership love them too and say it's the setup they (privately) recommend if a car is off warranty and the owner is going to do their own work.
#14
I got the brake wear indicator light on my dash a couple weeks ago. I changed out the rear pads and rotors tonight using my Vag-Com. Except for fighting a couple of things, everything went well.
After ending lining change mode with Vag-Com I hit the brake pedal a few times and activated the parking brakes a few times and the brake light went off and everything felt fine.
Now I have a parking brake warning light on my dash. It's the brake symbol with a 'P' in the center with a line through it. Wouldn't you know it I have a vacation scheduled in two days.
Does anyone know how to get rid of this indicator light? I tried going back into Vag-Com and initiating the start and end the lining modes again, but I only get an error message and nothing happens.
#17
Hey, thanks a lot guys. I feel really stupid and really old about now. I'm still a noob when it comes to a Vag-Com.
I ran a fault code session which said I had an open electrical circuit in the parking brake system.
Even though I was sure that I had hooked the parking brake wire connector back together I found it still unplugged.
Everything is working the way it should as far as I can tell. I'll take the car out later today and bed in the ceramic pads.
These technic's worked well for me on the rears:
After spraying and hitting on the rotor which seemed like forever, I placed the pointed end of a die bar in one of the cooling openings, pulling it towards me while smacking the rotor.
A few good hard wallops and it pops right off. (I know the rotor screw is still in, needed it to hold the rotor in place for the picture.)
I was able to retract the brake piston by removing the caliper and brake pads and then reinstalling the caliper (w/o pads) and inserting a die bar gently moving the piston back. It takes very little effort to move the piston.
#18
I removed the guide bolts and used a pair of clamps to push the puck back into the caliper. Because I had my 45K service the week before, I had to remove brake fluid before retracting the pucks.
I removed the rotors by squirting penetrating oil in the stud holes and center hub, removing the caliper carrier and squirting oil on the hub from the inside. With both rear wheels off the ground, I could rotate the rotor while hitting it with a hammer on the outer edge. A couple rotations and it popped off.
Here's a shot of a pad wear sensor half way worn through
#20
If you decide to change rear rotors, these are decent replacements - $94 each shipped.
http://www.ebay.com/itm/191889371693?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
