DIY on rear wheel bearing - AudiWorld Forums
A6 (C7 Platform) Discussion Discussion forum for the C7 Audi A6 produced from 2011
Sponsored by:
Sponsored by:
Old 10-29-2017, 12:38 PM
Default DIY on rear wheel bearing
Did a search and saw others who have done the fronts with buying the hub and the bearing as one piece.
Question is I dont see anyone who sells the REAR bearing and hub together. Have anyone replaced rear bearing DIY? Do you need a press? and how complex is it? The front looks straight forward replacing the hub with the bearing in it already
Thanks
Vodka G is offline
Old 10-29-2017, 02:51 PM
The bearings and hubs for both the front and rear use the same part numbers. I would assume the front assembly would also work on the rear.
xanmato is offline
Old 10-30-2017, 08:35 AM
OK found the part # 8K0407607
...but it looks like they don't sell them together with the bearing already pressed into the hub.......at least ECS don't have them together. I called the dealership and they told me that part is discontinued..... they see that now as the bearing by itself and the hub by itself....
Vodka G is offline
Old 10-30-2017, 11:21 AM
There is a TSB about wheel bearings in these cars. I'm not sure if there is a warranty or mileage requirement but it is referenced in the following thread:
https://www.audiworld.com/forums/a6-...=wheel+bearing
halyard405 is offline
Old 10-30-2017, 03:23 PM
thanks! it looks lie is just a TSB and doesn't ext the warranty or what not.
Vodka G is offline
Old 11-14-2017, 11:17 AM
Update:
Wheel bearing replaced by Audi Dealer, they covered the parts and I paid for labor. they also found ripped front control arm bushing....which they covered the parts as well.....
$1400 usd for labor of both rear wheel bearing and both front lower control arm bushing plus alignment.
is not cheap but not that bad either
Vodka G is offline
Old 11-14-2017, 12:08 PM
Nice. I'm glad you got it fixed to your satisfaction. Happy driving!
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
