TechCom-Mike |
08-12-2018 01:48 PM |
Engine mounts visual check
Okay, first off, being a 2015 with 27K miles that runs as smooth as silk at this time, I have no reason at all to suspect that the engine mounts are in trouble. That said, since my car's in the Passenger AirBag recall issue and its warranty will be up in late Feb 2019, I'm figuring that if they actually do the recall job between now and then, I'll probably have the Dealer do an Oil change at the same time (only 2K miles but 6 months since last one) and the question is this; from the vantage point under the car doing the oil drain, is it possible for them to conduct a reliable visual check of all the engine mounts or are they tougher to see than that?
