Failed BMW Experiment!!
#13
Stand in my garage and look at our 2016 Audi with the "lurchomatic" transmission ("they all do that since the 2016 refresh", according to the dealer), erratic HVAC and audio systems which just leave the dealer puzzled, door handles which sometimes lock/unlock and then don't, out of round brake rotors which Audi refused to cover under warranty, pretending out of round is a "wear and tear" issue, even though rotors and pads had plenty of thickness...
Then look at our 2015 BMW parked next to it after three years, which had one door trim rattle, fixed, and has performed flawlessly since...
Then look at our 2015 Subaru which just goes flawlessly, as some Japanese brands are prone to do...
Then look at our ~10 year old Jeep which needed a window switchgang and one new battery in a decade...that's it...and just keeps going
You may understand that your witticism about which brand is the "failure" for us, and indeed, which feels like an experiment, is not universally shared
There will be more BMWs here (along with other brands)...there will never be another Audi. I can't trust the car and I can't trust the company.
#15
As pointed out by the OP and subsequent posts, there will be those with good experiences and those with bad experiences with both brands (true of any brand actually). With that in mind, let's keep the comments respectful.
#16
Agree completely....the quoted quip about another brand being a "failed experiment" in totality was enough out of bounds to prompt my reply....I have usually become otherwise quiet here.
#17
2016 A6 P+. No problems hereafter 26,000 miles. Sounds like electronic glitches. Maybe disconnect battery and wipe out issues. Or some other re-boot strategy. Have you tried contacting Audi corporate?
#18
So many sw update types on these new cars:
1) ECU Update - only by dealer - There was an emission related ECU programming recall on this model year, worth it to check if your's needs this and request dealer to use the opportunity to get ECU to most current version.
2) TCU Update: only by dealer - I had to pay $70 at local dealer that charges 130 per hr.
3) MMI Update - can be done by you or dealer - sw available freely online if you know where to look. However, if done incorrectly, you run the risk of bricking your mmi. I know because I did and paid $200 for used one off E-Bay. Tried it again and did it correctly. We live and we learn. Dealer was kind enough to adapt it to my car for free when doing map update.
4) MMI Nav map update - only by dealer - have to pay 250 for maps plus 1 hr labor. Any dealer wanting to charge you for how long it takes to download the maps on the VAS equipment is a scam artist. The tech kicks it off and proceeds with other work until it finishes. I paid 350 for my update last year.
#19
Yes, and found the source of poor customer relations and dishonesty is not at the very friendly and helpful dealer; it originates from HQ.
Dealer checked VIN and found no official updates, but offered to do a "clutch reset" under warranty to wipe out all existing memory and re-set. He pointed out that if any improvements have been made in the interim to the OE TCU codes, but without issuing an update, they would find their way into our car with this procedure. We will make an appointment to try that. Thanks much for that tip.
#20
