Halogen headlight issues.
properly (soldering heat shrink etc) still nothing. The next day after that my high beam bulb went out or so I thought. I swapped both bulbs from passenger to driver side and they worked fine in the driver side. So I figured it must be a fuse or something except my owners manual only shows the fuse diagrams for cars equipped with HID or LED bulbs and that's all I've been able to find online too. OBD11 is showing code 01499 and code 00979 (pictures attatched). So now my low and high beams both dont work on the passenger side but every thing else works great (turn signal, corner marker, and drl) Anyone have any helpful tips on this? Maybe there is a fuse somewhere I'm not finding? I've looked in all the spots it says to look (trunk, driver side of dash, and passenger side of dash) with no luck. Everything is plugged in fully and is clean (no corrosion) I'm at a loss.
