Help with keyless go function
Old Jan 1, 2018 | 08:10 AM
Lord's Avatar
Default Help with keyless go function
Hi, I'm new here, recently bought A6 2012, have question about sensors on door lock, I see on Youtube I can unlock and lock car only touching sensor on door lock. (no need to use remote control) Tried but didn't work. Can someone give me instructions how to use this? I have Advanced key.
Thanks in advance,
Happy new year and holidays!
Old Jan 1, 2018 | 12:49 PM
Mesquite77's Avatar
Should work, but try easy stuff first: Both car battery, and your key fob battery need to be good/fully charged. If car battery gets old or weak, and it sits for a while, car will disable touch entry. Same thing if key fob battery drops below about 3.0V.
Old Jan 1, 2018 | 02:06 PM
Lord's Avatar
Thanks for info, I will check both batteries...
Old Jan 1, 2018 | 04:55 PM
Silver42's Avatar
On 2012 and I think 2013 - the keyless stuff was only on the prestige trim. Premium Plus did not have it - or was an option.
Old Jan 1, 2018 | 05:09 PM
DB22's Avatar
If the car battery is low then the car won’t start as the starter is the biggest load on the battery. If the fob is low then you will get a warning that you have to hold it near the icon on the dash to enable the car. My guess is that the car is not Prestige but the OP did not specify location and models were different around the world. The OP did not disclose options either so it’s a guess at best.
Old Jan 2, 2018 | 03:21 AM
Mesquite77's Avatar
In USA, 2013 PremPlus includes "Advance Key" as part of the P+ package (why I have it). OP says he has that option, so hopefully it will work out.
apoelistas
Q5/SQ5 MKI (8R) Discussion
84
Jun 26, 2024 10:19 PM
manuelku
Oct 26, 2004 12:17 AM
rfan-r32
Aug 27, 2001 07:13 PM
Onemax
Jan 20, 2001 06:32 AM
