Part No. for jack post
Old 10-07-2016, 06:52 AM
r1racer's Avatar
Default Part No. for jack post
Looking for the part number for the posts to jack up the car.
Old 10-07-2016, 02:48 PM
tenspeed's Avatar
My used A7 was missing one of the plastic jacking sockets. I cut a piece of 2X2 that worked but you can see in the picture, I had to cut a new piece of wood or find a better solution. I had a piece of "U" shaped metal scrap from building conduit pipe racks. It was close to size of the wood and came with 1/2" holes in the back.
I used my right angle drill to make the holes because my regular drill wouldn't fit under the car on ramps. A couple of threaded holes later, the piece was in place. I couldn't see paying for a piece of plastic to replace one that failed.
The car on a lift during the exhaust installation.
Old 10-08-2016, 02:22 PM
r1racer's Avatar
Creative...have you tried it with the widowmaker?
Old 10-08-2016, 06:41 PM
tenspeed's Avatar
I took a bit to realize what the "widowmaker" was. No, I haven't used the OEM jack. I don't plan to unless it's absolutely necessary.
It has been up on a regular floor jack several times using a jack pad. I had to buy a lower jack because I got tired of driving up on a 2X8 to get clearance needed to use my old jack.
Old 11-28-2016, 08:45 AM
50pascals's Avatar
FYI - Audi apparently doesn't have a part number for this item. This is not an Audi item, more of an industry standard. Some companies that make automotive lifts have them.
I just ordered 4 off Ebay.
Do a search for "Audi jack pad" or click the link below:
https://www.google.com/search?q=audi...w=1536&bih=742
Old 11-28-2016, 08:53 AM
DanfZX14's Avatar
Not sure if you mean this. I bought one so I could use my standard floor jack with the A6.
http://www.ebay.com/itm/Audi-Jack-PAD-Adapter-Audi-R8-Audi-TT-Audi-RS-Audi-S-Chassis-black-/331979584781?hash=item4d4b86750d
Old 11-28-2016, 09:30 AM
porksoda's Avatar
i have been using a hockey puck and works just fine.
Old 11-28-2016, 12:02 PM
the_duke's Avatar
I have the fancy one linked above and a few hockey pucks. I prefer the hockey puck.
Old 11-28-2016, 04:17 PM
50pascals's Avatar
The problem with the hockey pucks is they bear weight on the edge of the plastic "box." which leads to the the box crushing a bit. The bottom (or top) of the plastic box has a ton of ribs and will bear the weight without defelcting.
I have used the hockey pucks thus far. But can't stand the sight of the trim deflecting on the lift arms.
Old 11-28-2016, 04:34 PM
DanfZX14's Avatar
That's why for me the $13.99 was a no brainer.
Quick Reply: Part No. for jack post
