Inconsistent brakes feeling/resistance
I love all aspects of A6(C7) except the brakes. At first I was disappointed with the soft touch pedal. Even sometimes the pedal travels a little more than I expected so I have the uncomfortable feelings when braking. The brakes are working fine for stopping though.
The brake fluid bleeing does not help. I tried the bleeding twice. The audi services said that the brakes have no problems.
If this is by design, can I get some improvements by replacing with the whole brake systems such as the brembo or stoptech? Any help will be appreciated.
It's probably a combination of master cylinder sizing and the amount of brake booster assist. Changing the former trades pedal travel for effort (i.e. less travel = more effort required) and either will require physical hardware replacement. I have doubts that there are a lot of options for changing anything on this chassis yet. If the S6/7 exhibit better brake feel, then perhaps components from those cars could be retrofitted.
Anyone driven both and care to comment on any differences in braking feel?
4 grands for brembos
Just bolting in aftermarket calipers could potentially make it worse, as you need to balance master cylinder size with the piston sizing of the caliper. Your best bet is to try a different (preferably harder compound) brake pad. There are types that require more effort and subsequently add a little feel to the pedal.
I upgraded my front brakes to 380mm brakes that Stasis offers. This also included SS brake lines for the front brakes and new higher temperature brake fluid. The prinary reason I did this was to eliminate the mild fading I would experiance when participating in High Speed Driving Events on the track. That said they did improve overall break feel for me as well as improve braking which was already excellent with the stock brakes. The Brembo and Stasis brakes are very similiar so I would expect similiar results with the brembo brakes as well. I did replace the the brake fluid that Stasis provided with even higher temp brake fluid. I did this fluid change myself using a brake bleeding tool I purchased from ECS and the help of my son-in-law. I think it made the job really easy and pretty much guarantees no air in the lines.
If so, this seems horribly unsafe, and should be investigated for a NHTSA recall.
I have heard of this complaint before, however, I have never experienced it on my A7.
Clarkss
08-20-2016 07:56 AM
Jon-1.8t
03-08-2006 06:46 PM
jimngo
02-15-2005 08:22 AM
Thermal
02-21-2002 04:19 PM
