LED DRL Discoloration
I’ve got a 2016 with full led lighting package. The DRLs seem white on the outside but where they taper together towards the grille they begin to turn yellow. To the untrained eye people would shrug it off if they could even see it. To me it’s glaringly obvious and drives me nuts. Does anyone else have this issue? Is it possible to switch out the leds themselves or is it a power issue? I wanna get these bright white again but don’t wanna spend $6000 on headlights. -_- Thanks for any help/direction.
Led Power
I think the leds are losing their power. I have a similar problem. Mine is 2011 c7, the passenger side has a yellow-white colour but the driver side is white which is replaced 7 months ago due to a small accident . So I gave the passenger side for a professional cleaning but they warned me that it will not change because it is not dust giving this yellow-white colour, it is led power which is 8 years old. But yours look a little bit too soon...
So your whole headlight was replaced? I want to just replace whatever is driving that power but I don’t think that’s possible. On a 2011 is start to expect it like you said but on a car that just hit 3 years old is a bit absurd.
Same issue on b8.5
I have the same issue on my passenger headlight in my S4. That DRL is yellowish towards the grill. The other is bright white. I actually purchased a spare AFS headlight and moved over the modules and it was the same color. So I ordered the DRL controller and replaced that. To my surprise it did not change a thing. Still perplexed...
aykutalp (12-19-2019)
2015 A6 c7 premium plus pre-facelift
I have the same issue starting to happen... passenger side is starting to clearly turn yellow.
I've looked around and haven't found info on a fix, besides a new headlight.
Usually LED's last a VERY long time and its only a 5 year old car. Not sure if LEDs in cars are different.
Could it be the ballast going bad? Or is that just for the HID bulbs?
Hope this helps.
The following 4 users liked this post by drecon23:
