Map on HUD?
Old 04-21-2019, 08:37 AM
UCLABB's Avatar
Default Map on HUD?
There is an option on the MMI for the map to be on the HUD. Even though I selected the option, it doesn't appear. I'm not that sure I would want it anyway as it seems that it would be a distraction. I thought it might not work because it is disabled for that reason.
Isn't it working for anyone? Do you find it useful?
Old 04-21-2019, 02:08 PM
lardog's Avatar
Try selecting a destination and route there. Then see if the route map shows up.
Old 04-22-2019, 03:50 AM
2016_A6's Avatar
Actually, it's not a display of the map. It's a display of upcoming turns. If you are coming up on a turn you need to make, it's simply a picture of an arrow with the turn direction along with a gauge that shows how long until the turn, decreasing as you get closer. On my A6, the map appears on the main screen, and also on my gauge cluster.
Old 04-22-2019, 04:12 AM
KevinGary's Avatar
same on my 2015
Old 04-22-2019, 06:12 AM
UCLABB's Avatar
Ah, that makes sense. I kinda felt the whole map would not be appropriate in the HUD. I'll put in a destination and give it a try to see if I like it. Thanks.
Old 04-22-2019, 06:15 AM
DanfZX14's Avatar
I truly love that feature!
Old 04-25-2019, 03:26 PM
ramaraju's Avatar
Can comeone tell me where is this option to enable that?
Old 04-25-2019, 04:02 PM
DanfZX14's Avatar
Put in a destination and give it a try to see...
Old 04-26-2019, 09:08 AM
UCLABB's Avatar
You first enable it in the MMI. I don't remember the exact menu, but if you search around you can find it. There are two options you can check, the map and speed.
As others have posted, the map (actually just the leg you are on and the next leg after a turn) only appears when you put in a destination.
It's a nice feature.
Old 04-26-2019, 09:11 AM
ramaraju's Avatar
Found it...It's a nifty feature to see the turn by turn indications..
Thank you folks
Quick Reply: Map on HUD?
