Misfire on cylinder 3. Running out of options, any suggestions?
2013 A6 3.0T (USA) with ~140K miles. The catalytic converter on bank 1 is faulty, P0420. (same side as Cylinder 3)
The vehicle consistently throw a DTC for Misfire on Cylinder 3, ONLY after ~5500 RPM. It goes into limp mode - EPC light on. Restarting it twice resets it and it drives well until hitting that RPM ceiling again.
I changed the spark plug to a brand new Audi NGK and swapped coil plugs; also tried a brand new coil plug. Exact same behavior.
Unfortunately I am on a tight budget and I have to get my hands dirty as much as possible to reduce cost. I would appreciate any suggestions of what else to try.
Some ideas:
- Can a clogged catalytic converter cause this?
- Can it be an injector, despite no related DTCs?
- The Audi indie shop mentioned a EGR / PCV issue that may cause this?
Thanks.
Some ideas:
Thanks.
you may have a clogged injector, I took mine for cleaning and one was not that great during initial testing. Try running SeaFoam in your gas tank, 1 can per tank - at you own risk! That may help, i've done it before and it worked. I also have clogged catalytic converter on bank 1 but rarely i find a code for low fuel pressure in bank 1, so that could be playing a part with a back pressure or something. Another thought, and that's just a thought, maybe your intake valves are super clogged and fuel/air mixture is off causing misfires. Mine were really dirty
Bank 1 - closest to bumper
Bank 1 - middle
Bank 1 - closes to firewall
Bank 1 - middle
BOPOH could be onto something with the valve coking thing if its not something else. Search the forum as there is a good thread on this topic. Good luck!
Thanks BOP and Dan. I will keep you guys up to date.
A bit of back story that may be pertinent. This all started 1-2 weeks after I went Seafoam and CRC GDI cleaner crazy. I ran about 5 Seafoam cans and 4-5 CRC GDI cleaners through the vacuum line over the course of 2-3 days.
The car started running very poorly as if a block or restriction (cat?) I then ran 3 Cataclean which seemed to bring it back to normal, excluding this problem.
I have experienced the same issue and it was caused by a bad injector. if you want to confirm just swap injectors between two cylinders and if the misfire moves you will know that is the faulty part.
Fuzzbeaner
Audi 100 / A6 (C4 Platform)
06-18-2006 04:08 PM
Pekboy
03-09-2004 09:02 AM
