MMI connect app, Send to Car
Has anyone used this feature lately on their iPad? I cannot even find the google map or a send to car button. Inrix have got the map with Find Car or Traffic.
I am assuming one of two things; I'm missing how this new abomination works or they had some high school writing software geek "fix it". |
Is the iPhone app different from the iPad app? It works for my on my iPhone.
I think there an update pretty recently as well. |
I use it regularly on my iPhone. Not sure if the UI is any different on the iPad, but not sure what your issue is. You don't even need to open the app to send a destination to the car. You can do that from any app that can share a location. Look up a place in Apple Maps, Google Maps, Yelp etc. than tap on the share function (in some apps it's a text link, in others it's an icon etc.) and choose the MMI Connect App as the share target (tap on More if it's not showing up), from there tap on Send in the top right corner or press and hold the small car icon and drag your finger towards the top of the screen to drag and drop the destination to the car. If you tap on the name, you can rename it first as some apps give it a generic name such as 'Dropped Pin'.
Thank you for the information. I used to use the map in the app and then send to car. I did not know about the procedure described above using Apple maps or Google maps.
My Iphone and Ipad work but the PC hasn't worked in years. |
Google Maps send to car from a browser on my PCs and Macs works fine, too. I almost use that more frequently. I use the connect app mostly to send calendar appointments directly to the car.
Google Maps send to car needs to be configured properly. It's a bit confusing. You need to have matching account names on both sides. The account name I'm talking about is different from the email address to login to myAudi and is also different from your Google account. If you login to the myAudi site there's a section to configure Google Maps send to car under Audi Connect services. There you'll find an account name setting that you can edit freely, as long as it is unique. Whatever you have there, the same value needs to be entered in Google Maps where you configure send to car. That's the account name that both sides use to identify your car. |
1 Attachment(s)
This is the page to configure Google Maps integration in case you can't find it.
Originally Posted by superswiss
(Post 24865583)
Google Maps send to car needs to be configured properly. It's a bit confusing. You need to have matching account names on both sides. The account name I'm talking about is different from the email address to login to myAudi and is also different from your Google account. If you login to the myAudi site there's a section to configure Google Maps send to car under Audi Connect services. There you'll find an account name setting that you can edit freely, as long as it is unique. Whatever you have there, the same value needs to be entered in Google Maps where you configure send to car. That's the account name that both sides use to identify your car. I configured at my audi thw Google ID account. I tried to enter my email address there, I tried to enter a random nickname, i tried everything, I can't find in that link something about to add my car.... |
How about you add the information about your car in your signature, so we know what you're dealing with. None of us are clairvoyant, you know...
Originally Posted by minovg
(Post 25000024)
Can you give me more information?? In google.gr/maps/sendtocar i don't see my car, I even can't add my Audi.
Sorry mate you are right...
(Post 25000175)
Adding location under your avatar is the best solution as readers can easily see it at every post. |
