MMI Oil level monitor after Service
Just thought I'd mention a slightly curious event (to my mind) as, following an Oil and Filter change at my local Audi dealer Friday, the drive home due to some traffic avoidance probably was 15 miles and took 25 to 30 minutes. After switching off, I then brought up the MMI Oil gauge to check the level and was surprised to find it only slightly more than half way up the low to high span. Now if only equipped with the electronic gauge I might have been tempted to top up right then (after all, car had run for a half hour since the oil change) but because I bought an old fashioned dipstick shortly after buying the car, I ducked under the hood and read it the primitive way. The dipstick showed a perfect read at the full line! So I opted not to follow the MMI or put in more oil, fearing I could over-add and the computer would soon be asking to remove some oil. Sure enough, after driving the car the next morning, I return home and check the MMI Oil again - lo and behold now it says absolutely full (yet I hadn't added a smidge). Maybe 30 mins of driving after an oil change isn't enough to register properly the electronic way but the moral of my story is be wary of the MMI and my advice is don't go just electronic but get a back-up dipstick just in case. I've linked the one I bought below. They should be sending me freebies as an endorser; though they aren't aware I am one.
https://www.europaparts.com/oil-dips...6e115611h.html
