mmi software update to have apple CarPlay
Hello all,
I searched on the forum site. But I could not get it correctly.
I have Audi A6 C7 2011 Sedan with MMI 3G+
is there way to update MMI software update to use apple car play in my car?
is there some one have this update disk?
I really do not know ways how to do it.
many thanks.
many thanks.
You can not get it with an update but you can buy a module that will give you carplay and it works pretty good.
https://www.audiworld.com/forums/a6-...2907602/page7/
thank you for your answer.
I found this link that it cannot be possible for my car.
https://shops.audi.com/en_GB/web/zub..._ASOS:Category
I guess I should start to searching for aftermarket products.
BR
BR
BR
BR
I was hoping that update would work for my vehicle also since I'm a 2016 but its only for MY17 and newer. You have a 2011 so its not on the list anyways. The aftermarket kit is nice cause you can also mirror your screen.
Its possible with an add-on device for your 2011, see here: https://www.audiworld.com/forums/a6-...tions-2949810/
I found something; check this out!
this is the link: https://www.audi.de/de/brand/de/tool...re-update.html
and in the page it says;
The software update for Bluetooth interface or Audi connect in conjunction with MMI radio / MMI navigation is only available in the A1, A6, A7, Q3, TT and R8 starting from the production month of June 2014 (model year 2015).
But! if you open the pdf file; it is written there;
If the system update item does not now appear in the concert radio / MMI radio,your concertradio / MMI radio is not ed for this update. Note: the software update for the mobile phone preparation (Bluetooth) or Bluetooth interface in conjunction with MMI radio / t adio is only available in the A1, A6, A7 and Q3starting from oduction month of June 2011 (model year and A3 starting from the production month of August 2012 (model year 2013). As at: June 2013.
I will just copy those files to sd card and plug to the car and try to update.
lets see... I will comment here again later after I try again.
and I found there guys https://upgrademyaudi.net/
BR.
BR.
hello guys again,
I found this pdf: https://www.scribd.com/document/357273000/3G-3GP-V2
and add this pdf file here too.
and here is download links from this pdf:
UPDATE INSTRUCTIONS FOR MMI 3GP (7T6)
By Congo – written Q1 2016, updated Q4 2016 – Version 2
Pre-requisites
MMI 3G+ systems with relevant PR no.: MMI Navigation Plus – 7T6
Obtain the needed software updates
Audi A1
8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Modified - Untouched
Audi A4-A5-Q5-Q7
8R0 906 961 EB – HN+_EU_AU3G_K0900 (A4/A5/Q5/Q7) SVM: 3GPEU900AU3G
8R0 906 961 FC – HN+_EU_AU3G_K0942 (A4/A5/Q5/Q7) SVM: 3GPEU942AU3G
Audi Q3-A6-A7-A8
8R0 906 961 EA – HN+R_EU_AU_K0900 (Q3/A6/A7/A8) SVM: 3GPEU900
A high quality SD Class 10 for faster (and safer) file operations.
The separate firmware upgrades are bellow 1GB in size but the map is 29.1 GB hence the 32GB SD.
The modified version of the firmware does not need the green menu to enable the user defined mode.
It also does not contain any updates for the sound system. It will activate the green menu during installation.
BR
Dev
Pre-requisites
Audi A1
Audi A4-A5-Q5-Q7
Audi Q3-A6-A7-A8
BR
Dev
I don't think any of this will result in Apple CarPlay being activated, it looks mostly to be an MMI and Navigation database update. Please be careful, I've seen some posts where people tried this themselves, and ended up at a dealer to fix an inoperable MMI - at a high price (thousands). Good luck!
To all the nubies (how do you spell it?) on our forum...if you have the 2.7T you will like this link
paulroad
Audi allroad
02-17-2008 02:23 PM
geordie
11
06-04-2007 05:54 PM
Stoney
17
04-30-2004 06:47 AM
