Navigation system question
#21
If it wasn't equipped with GPS it wouldn't even start initializing. There are models/configurations where one could have the Nav button, but not actual Nav function. That can happen in markets like Europe for example, where for certain models you can option the MMI. I don't remember the actual message that you get in that case, but it's more along the line of "This car is not equipped with this function". I'm paraphrasing here.
In your case it's actually trying to initialize, but then somehow gets stuck. Dumb question, have you tried to do a hard reset of the system? You press Menu, **** and upper right corner button at the same time. That will perform a reset. If that doesn't work, go into the main settings (Main Menu Setup MMI) and perform a factory reset of the entire system. If that still doesn't do it, then it's time to visit an Audi dealer and have them figure out what's wrong.
#22
Seems like there's no version info or DB of NAV? I'm not too sure. Where's the NAV hard drive located? I just wanna see if it's even there.
I can see I have this.
#25
So, the one thing I'm glancing from your firmware version is that somebody performed an update to it after the factory. That's revealed by the letter K in K0039. If it was still running what the factory installed there would be the letter P. So, one guess here is that whoever did the update screwed something up.
#26
#27
The HD is part of the head unit, which is in the dash above the climate controls. Judging from the version # I believe this car has the 4G MMI. With the 4G MMI and Audi connect, the map database can be self updated over the car's mobile broadband connection or by downloading it from the myAudi website. However, looking at your screenshots it looks like Audi connect is not available in Hong Kong, because I don't see the data connection logo in the bottom right corner, so my guess is only a dealer can sort this out for you.
#28
Maybe if you put your location under your avatar and you model and year in your signature then some of your questions would have some relevance.
#29
Just wanted to post an update! I managed to have my Navigation recovered after bringing it back to Audi. They had to restore the whole MMI system for me. Happy now!!
