OBDEleven question - Comfort blink
Hi,
2016 A6 Prestige 3.0L
After searching our forum and OBDeleven's I found the following:
Comfort Blink Cycle
Select Control unit 09 (Central Electrics)
Security access
Access Code 20113
Adaptation
Channel 31
Valueı: 1-5 Value 3 (standard - 3x blinking)
I have the Pro version of OBDEleven and cannot make this change. When I get to Central electrics - security access 20113 is accepted - pick Channel 31 (or 031) I get an error that "request not recognized" or something similar. No current value (3) is displayed and I have no opportunity to enter a new number.
Any thoughts? I'm reaching out to OBDelven too but thought some of you were successful making this change.
Thanks
Steve
Comfort Blink Cycle
Security access
Access Code 20113
Adaptation
Channel 31
Thanks
Steve
No one since the MY2012 C7 has been able to change the turn signal 3 blink count with any Vag tool including VCDS. I doubt it will work on the MY2016 either. The only workaround I've found is to tap the stalk once and then after the first blink, tap it again. This will give you more continuous blinks.
