One Tire or Two (and front vs rear)
I got 4 new tires about 3,500 miles ago (on a 2013 A6 3.0 w/ 20" wheels); the tires still have almost all of their tread left. I hit a pothole and got a sidewall bubble that is big enough that I want to replace the tire (the tire shop said I could "probably" just keep it, but I want to err on the side of safety). My first question is whether I can get just one tire vs. whether I need to get two. In either case, should I rotate the tires such that the new one is either on the front or on the rear or does it not really matter?
Thanks
Thanks
Definitely would replace the bubble tire. At that low mileage front or rear doesn’t matter but in a case with more mileage new tires ALWAYS go on front axle, ask Tire Rack, they will tell you that. A tire with sidewall bubble is unsafe period.
Happened to me, tread difference less than 1/32, so doesn't matter, but my rears wear quicker than the front, by about 1/32 (more) per 10K, so if you put it on rear and rotate just one side after 10k, they'll all be even again in 20K...
I found that I have the most wear on the right rear tire. I tend to corner harder on left-hand turns.
I have three sets of tires and check tread depth with every change.
Thanks
Thanks
