P200600, P200700, P001600, P034100 what to do?
Hi, got those fault readings after the engine was top overhauled because of the water coolant had sipped into the engine block and mixed will the lubricant. My car is a 2011 a6 c7 3.0 TSFI
a) p200600 - intake manifold runner control bank 1, stuck closed
b) p200700 - intake manifold runner control bank 2, stuck closed
c) p001600 - crankshaft position-camshaft position, correlation bank 1 Sensor A
d) p034100 - Camshaft Pos. Censor Circ., Range/Performance.
What is the solution for these problems.
Thank you.
Thank you.
Thank you.
Thank you.
Thank you. Turned out that it has something to do with one of the timing chains which is not properly set. But the engine must go down again nevertheless. Another week wasted.
Homeostasis
4.2 V8 Discussion
03-10-2021 09:42 AM
A3-Mojo
Audi A3 / S3 / RS 3
10
10-21-2007 11:35 AM
