Raising Windows via remote with OBDEleven?
Very cool that I can now lower all of my A6's windows at once with the remote control now that I selected and paid for that option with OBDEleven Pro. However, I did the same thing for my Q5, and the remote can now both lower AND raise the windows. For my A6, if can only lower them. Are others finding the same thing, or did I do something wrong? I went into the MMI's settings to ensure the new option was checked off by the way.
Operating Windows and Sunroof with Remote
This will allow/enables remote closing of the windows and sunroof by holding the Lock button on the remote control. In addition, it adds an menu item in the MMI to optionally allow opening the front windows/rear windows/sunroof by holding the Unlock button on the remote.
- [46 - Cent. Conv.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 2-> Bit 2
- Check "Comfort Operation: Remote Control active" box.
- Save
To Open Front Windows and/or Rear Windows and/or Sunroof with long press of Unlock button on remote:
- Reboot MMI to make sure the menu item appears (press Menu, Big ****, and Top Right Soft Button simultaneously)
- Use the New MMI Menu to Change MMI Settings to allow remote down
- MMI: [Menu]->[Car]->[Car Systems]->[Vehicle Settings]->[Central Locking]->[Long press to open windows] -> Set Front Windows, Rear Windows, Roof to “On”
OutietoInnietoAudi (11-02-2021)
You should be able to? Mine work but I did do it with the VCDS software so your mileage may vary. Here's what I got:
- Save
I've got the windows on my 2012 A6 to both open and close via the key fob with OBDEleven, so it is possible. I don't have my car with me right now (in the middle of a cross country move), so I can't look at my settings, but I basically did what DanfZX14 said and it worked.
Last night I did a bunch a customization with the app Carista. I was able to go in and turn on the windows up with remote. I also to fool my friends into thinking I got an RS6 by changing the display screen at startup lol.
That's really weird that my key fob can remotely put down all windows (and sunroof), but can't close them. Was it the same app in OBDEleven that you used to turn on both functions? or a different app for each (up/down)? If the latter, I wonder what went wrong with mine..
