Raising Windows via remote with OBDEleven?
#11
The only setting I see to enable is the "Lower Windows with Long Press" setting. And then I can check off for the same for the sunroof. There is no similar one to enable to raise the windows with the remote. Maybe it's different on the C7 cars, as I have a C7.5 and it looks like you have a 14' (C7). And the poster just before you said he had the same experience as I and he has a C7.5 as well.
#12
Are you referring to settings you see in the MMI or the OBDEleven App? I will try to look at mine tonight and take some pictures/screenshots.
#13
Again, same here. On our cars, I am wondering if it is not an adaption that we need to set for it to show on the MMI in addition to the coding that we did.
#15
I used the Carista app as well. However I can only make the driver's side window go down. The long press lock can make all the windows and sun roof close. Did you do something different in the app?
Thanks,
Thanks,
#17
Regarding the coding with OBDEleven Pro, are you using long press of unlock button on remote to open all the windows, and long press of lock button on remote to close all windows? (my issue is that I can't close them with long press of lock button.) My guess is that your'e able to do both because you have a pre-face lift model. I bet us post-facelifters can't raise windows with the remote if we used the OBDEleven app.
#18
#19
ltooz_a6_a8_q7
Q7 MK 1 Discussion
09-23-2018 03:25 PM
CaryinTTown
07-23-2018 01:10 PM
