Eibach Pro Kit
Old 12-03-2013, 09:02 AM
krazyhabu's Avatar
Default Eibach Pro Kit
I'm about to order the Eibach Pro Kit and was hoping to get some last advice from people with experience coming from OEM Sport Suspension to the Pro Kit. I know there will be about .5 to .7 extra drop, but need more feedback on ride quality. Will there be a significant difference when it comes to sportier feel with the Pro Kit?
Or should I just keep the OEM Sport Suspension and replace the rear sway bar with the Stasis product.
Thanks
Old 12-03-2013, 06:21 PM
jr'sAudiA6's Avatar
Thanks
Not familiar with the Eibach Pro Kit but here is what I have done.
I had the Stasis touring suspension installed for about 18 months but I recently had the KW Variant 3 installed with the Stasis rear ARB remaining in place. One problem I ran into with this install was the KW kit was missing a 30mm spacer for the rear springs. It goes between the perch and the top of the spring. With out it I was riding on the rear shock bump stop but now all is good. Really love having a fully adjustable suspension, i.e. height/compression/rebound, thou it is a manual adjustment. I also recently had adjustable upper control arms installed in the front so now I have camber/caster adjustment for the front suspension.
Old 03-28-2014, 03:06 PM
OSpacer's Avatar
Thanks
Can someone who went from SPORT suspension to eibach pro chme in? What is the real drop after the springs settle? How do the ride and handling compare?
Any before and after shots?
Old 04-05-2014, 08:11 PM
OSpacer's Avatar
Anyone?
There must be someone here with Eibach pro setup
Old 04-05-2014, 08:59 PM
Banned
feralc's Avatar
Originally Posted by OSpacer
Anyone? There must be someone here with Eibach pro setup
I do but not coming from the sport stock suspension
Old 04-06-2014, 04:28 AM
08A6's Avatar
I had the Stasis touring suspe.
From seeing others with Eibachs, do you feel that the Stasis springs were any lower than Eibachs or the same? It seems others have reported Eibachs had about a 1.5 finger gap..
Thx
Old 05-07-2014, 09:47 AM
quantumrace's Avatar
Did you ever pull the trigger and do the upgrade? And if so, what are your impressions of the ride change?
Old 05-08-2014, 08:11 PM
krazyhabu's Avatar
I went with Stasis suspension and I'm really happy with the ride comfort and handling. Drop is perfect and this is how it should be from the factory. I highly recommend this mod! JUST DO IT!
Old 05-09-2014, 04:51 AM
snagitseven's Avatar
Buying the Stasis from them now would be difficult as they have locked their doors and are not answering the phones.
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
gruvenparts.com
10-11-2016 04:47 AM
ECS Tuning-Audi
02-04-2016 08:36 AM
Kc Taylor
Q7 MK 1 Discussion
17
12-11-2015 07:21 PM
tonalvoltage
10-22-2015 07:11 PM
Quick Reply: Eibach Pro Kit
