Smelly car
#21
I would tell them they have a choice. They can use the TSB and do the recommended treatment there under warranty or you will bring it to a local AC shop (which there have to be lots of there) and have them do it and you will present them with the bill to pay for it. If they balk tell them that's what small claims court is for and you are perfectly willing to let a judge decide it.
#22
so does anyone have any documentation they can load up here that shows where all the drains are? Ive found the sunroof ones and 1 drain hose(under the car) for the ac.... Are there more? TKS!! much. still waiting to hear back again from the dealer.
#23
so attached is what they finally decided to do. the TSB number is different that what I had posted so im still waiting to hear what exactly they did. anyone have the details? they really took the time to put "its no defect in there". !!
the smell is gone for now. waiting for confirmation on best way to use ac so that the smell does not come back - the told me to run heat for 15 minutes before shutting off system and to only run ac in recirc mode.....
#24
I have access to the /13 version of this TSB which does involve a chemical "fogging" of the evaporator. Apparently the /14 version came out recently (June 2018) and I cannot access it from the Mitchell DIY database. If you would like to see the /13 version just PM me and I will send you a pdf.
#25
I have access to the /13 version of this TSB which does involve a chemical "fogging" of the evaporator. Apparently the /14 version came out recently (June 2018) and I cannot access it from the Mitchell DIY database. If you would like to see the /13 version PM me and I will send you a pdf.
#27
UPDATE: So the smell is back. Had procedure done on the 21st of sept and stayed odor free until the 29th. Now seems to be back. Did check holes in bottom of doors - no water came out even though they were covered by the rubber gasket. 2 holes per door if I remember correctly. Don't know of any other drains besides the 2 for the sunroof and 1 I found in front of the firewall - but that one looks to be more like a pass through for wires(there are none) rather than a drain area.
out of ideas and Audi closed the case and won't respond to emails or messages and the dealer doesnt respond either. too bad. I guess ill have to dry one of those foam sprays up the drain line. having trouble figuring out which brand is actually able to clean and KILL the potential mold and mildew and not just add deodorizer.
#28
Permanent S Mode Member
#29
I used this one in the past on a Honda car and it worked. It doesn't add any fragrance so you will know if it works or not.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#30
I had previously recommended a visit to a local auto AC specialists shop. I am sure that in your area there are lots of them who deal with this problem and can probably take care of it for you.
