Tire load rating - should i be concerned or not
#11
1 Post
Tire Pressures
So which tire pressure should I go by? The sticker inside the drivers door, or the tire pressure listed in the manual? I keep having tires that cup or feather shortly after getting new ones installed. I have the Audi dealer perform an all wheel alignment first thing, but the tires still cup. I rotate often, so what am I dong wrong?
#12
Per Audi, the driver door label supersedes any and all literature or specifications posted elsewhere.
As for cupping -and- feathering, it depends if it occurs on all tires or just one. If one, check the suspension for worn bushings or shocks/struts. If all tires, and the alignment is correct, the suspension and bushings are good, and the wheels are are not damaged, it's most likely you regularly drive on a nearby road that has naturally eroded or worn away to where it can cause tire wear when driven repeatedly at constant speeds. I used to live near a old road where studded tire use had made huge rough grooves, driving in them would shred new tires quite fast.
#13
#14
1 Post
Thanks for the reply. I have a 2015 A6 Prestige with 20" rims and there are 37,000 miles on the car. The cupping is only happening on the passenger side or one wheel to my knowledge. A recent inspection by Audi dealer did not note any suspension problems after specifically asking them to check for issues that might cause cupping. I'm thinking that the "full load" tire pressure that I have been running is too much for everyday driving and this may be the culprit. I also live in the San Diego area and the roads here are BAD. This has also happened to other Audis that I have driven. (A4s and A6s). A tire retailer once told me that this problem was caused by having Quattro.
#15
#16
Northern Goat
10-08-2018 05:41 AM
Small Town Terrorist
Audi allroad
06-15-2005 12:46 PM
ex-a8drifter
10
11-10-2004 02:14 PM
