Tire size
I didn't think a 5% change would do much but I checked Custom rims, wheel tire packages for your ride - RIMSnTIRES.com and it shows a one inch increase in diameter.
"Wheelwells clearance: Will fill out the wheelwell by extra 13 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims.
SPEEDOMETER: When speedometer reads 60mph (96.6km/h) actual speed will be 62.3mph (100.3km/h): 3.8% faster."
I can't recall ever buying a tire from a dealer. I usually use OEM sizes on my cars unless there is a monetary gain. I spent $200 less for the A7 Continental DWS 06's by going 10 mm wider.
