TPMS Not working and says currently not available
I'm hoping someone can help me as my Tire Pressure Monitoring system is no longer available and not working in my 2012 Audi A6. On the MMI screen the feature is now always grayed out (even while parked), and when I click on it, I see the following message, "The selected system is currently not available." It has been this way for months. Last night I hooked up my VAG cable and confirmed everything was activated correctly. So now I'm at a loss. Any help would be appreciated.
Thank you!
Thank you!
I recently had a greyed out MMI menu item like that on something that used to work fine. I pulled faults for the module using VAG-COM, plus the generic:
03157 - Functionality limited due to Communications Disruption
which turned out to mean that a wire had worn through, and the car computer had no link to the sensor.
So, I would first use VAG-COM to get all the faults, and then go looking for wires broken or harnesses that have come unplugged. Maybe the wheel speed sensor cables in your case?
here are the faults I found with the VAG tool:
05-Acc/Start Auth. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Details for 5F
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 H HW: 4G0 035 746
Component: H-BNT-NA H48 0902
Revision: -------- Serial number: 031J%0B7516589
Coding: 050200000003E9EF75128B3E10000003100001000000000000
Shop #: WSC 11394 001 1048576
VCID: 2C5684B44FCD7F2165-8078
Subsystem 1 - Part No: 8R0 060 884 AD
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1301T5HQ
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Serial number: 90349KJC000AJ
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 17
Mileage: 110324 km
Time Indication: 0
Date: 2017.03.26
Time: 09:17:20
Freeze Frame:
Text: DUA009,Front,M,0,0,6
03787 - Rotation Mechanism for Display Module Front
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 17
Mileage: 110324 km
Time Indication: 0
Date: 2017.03.26
Time: 09:17:20
I have it at the dealer now hoping Audi Pure Protection Extended warranty will cover it. The dealer even with the warranty is charging me $149 diagnostic fee, then they said IF they find something they call the warranty company to see if it is covered.
They called me around lunch and asked me when I got my APR tune because that might have caused the issue. I got the tune 2 years ago and the TPMS worked up until earlier this year.
Details for 5F
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 17
Mileage: 110324 km
Time Indication: 0
Date: 2017.03.26
Time: 09:17:20
Freeze Frame:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 17
Mileage: 110324 km
Time Indication: 0
Date: 2017.03.26
Time: 09:17:20
Problem found was the coding in the tire pressure module was incorrect. Dealer updated and it now works. Not covered under warranty. Not sure how that even happened.
stang32
04-30-2015 07:06 AM
parkinman
10-06-2009 05:11 PM
