VAG scan: Cylinder misfire - spark plug and coils
Hi guys!
I just wanted to get some advice. I got a code for misfire in cylinder 4 as you can see from my VAG scan.
I want to get on the road.
Also, should I worry about the other codes?
Thanks!!!
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0010
Revision: --H07---
Coding: 0A2A0034052600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 275D41CD5E228B7C46-8072
2 Faults Found:
7119 - Cylinder 4
P0304 00 [237] - Misfire Detected
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 131891 km
Date: 2018.05.19
Time: 15:29:31
Engine speed: 1550.00 /min
Normed load value: 31.0 %
Vehicle speed: 29 km/h
Coolant temperature: 96 °C
Intake air temperature: 30 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.015 V
Unlearning counter according OBD: 40
Engine speed: actual: 1280 /min
MAF_ENVD: 266.90588 mg/stroke
Coolant temperature (unfiltered): 24.00 °C
Engine: operating status: IS
T_AST_ENVD: 0.00 s
Vehicle speed: actual: 0 km/h
7948 - Cylinder Disabling
P130A 00 [109] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 131891 km
Date: 2018.05.19
Time: 15:29:31
Engine speed: 1478.00 /min
Normed load value: 20.8 %
Vehicle speed: 30 km/h
Engine speed: actual: 928 /min
MAF_ENVD: 157.96470 mg/stroke
Coolant temperature (unfiltered): 24.75 °C
T_AST_ENVD: 0.00 s
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 1006
Revision: --H08---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 3B758DBDB2AA3F9C32-806E
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 44A70F0122E5F0805B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 36639C898988E2F4CD-8062
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 0D882006000000000000
VCID: 7AFB48B9F510C69469-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H39 0046
Serial number: 2311000249125005
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H12 0062
Serial number: 18111100040208
Coding: 6601207A08
ASAM Dataset: EV_AirCondiComfoUDS 002033
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 285F42F1533C84044F-807C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001134545
Coding: 02002091163C9FE0C1008884A0003908CF9CD208A208012580 0008402000
VCID: 6ED374E9B9589A34C5-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 111019 H35 0051
Serial number: 111028172853
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11782413
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 08 11 2011 00001067
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R0W9B02
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0018322496
Coding: 853000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103381000000560556
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: FC08CAD5000000000001
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 B HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0480
Revision: 00000007
VCID: 2C57BEE14FC4A824AB-8078
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901131600039
Coding: 280106
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3D7183A5ACBE31AC0C-8068
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D8001KRL7
Coding: 303234373131303030314A55304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3365A59D9AFAF7DCEA-8066
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y160001GF8Y05
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40510UJCI5PR6
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404P0UJCI99QH
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40510TO4OH05C
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405T0R8AC0H2E
Crash sensor for front airbag: driver side:
Serial number: 3554VRB404R0ODISAHO/
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40510ODISIGBA
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20111116000912
Coding: 000014
VCID: 306FAA9163ECCCC497-8064
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0009
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 982 M HW: 4G8 920 982 M
Component: TBenUsa H79 0416
Revision: 25460175 Serial number: 658151111591013
Coding: 0BE609040B01D705020000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 3E7384A9A1B82AB415-806A
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000307206
Coding: 00C1033000
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3467A6819FF4F0E4F3-8060
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790113182
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0063
Serial number: 20111100040665
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002017
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 2F6DA9ED76D2D33C8E-807A
1 Fault Found:
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 227
Mileage: 130905 km
Date: 2018.05.09
Time: 16:22:34
Outside air temperature: 25.0 °C
Left rear vent temperature: 30.7 °C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000017379029
Coding: C0581B008F002001000001010101102030303232203232
VCID: 387F92B18B9C1484DF-806C
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4202TAXV0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51B3E57CDEA12CBC-8078
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011F17204E00628002000002
Shop #: WSC 02312 785 00200
VCID: 428BF059DD404E5471-8016
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 156
Mileage: 124616 km
Time Indication: 0
Date: 2018.01.18
Time: 18:51:13
Address 44: Steering Assist (J500) Labels: 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0008223481
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BA09965E0FED4E1-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0163321626
Coding: 0106023A00FA440580B0088002050000000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000058989
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO14144750
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00000555622
Coding: 010000
5 Faults Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 4
Reset counter: 143
Mileage: 95643 km
Time Indication: 0
Date: 2016.10.18
Time: 17:40:45
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Reset counter: 118
Mileage: 95712 km
Time Indication: 0
Date: 2016.10.20
Time: 19:25:30
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 17
Reset counter: 240
Mileage: 129128 km
Time Indication: 0
Date: 2018.04.13
Time: 15:31:10
03128 - Switch 1 for Sunroof
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 9
Reset counter: 217
Mileage: 130502 km
Time Indication: 0
Date: 2018.05.04
Time: 14:55:45
00204 - Sunroof Button (E325)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 217
Mileage: 130502 km
Time Indication: 0
Date: 2018.05.04
Time: 14:55:45
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 B HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0130
Revision: CJ007000 Serial number: 00000000033816
Coding: 030000
VCID: 1C376E211F6458A4DB-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 4189FF55D846554C68-8014
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000185936
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5BB8F94D30B61459-807E
Address 55: Headlight Range (J431) Labels: 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 111114-0004-036
Coding: 1221A633701AA400
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
VCID: 306FAA916BECCCC497-8064
Left Headlamp Power Output Stage:
H02 0008
Coding: 1E0000
Right Headlamp Power Output Stage:
H02 0008
Coding: 1E0000
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 156K40B7574572
Coding: 020007010000000001
VCID: 1F4D592D0E7243BC3E-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 C HW: 4G0 035 746
Component: H-BNT-NA H48 0423
Revision: -------- Serial number: 031K.0B7519517
Coding: 050200000003E1EF45128B3E00000003100001000000000000
Shop #: WSC 01999 444 183813
VCID: 275D41CD56228B7C46-8072
Subsystem 1 - Part No: 8R0 060 884 AD
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB13022Z0D
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349KKG000T0
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 66
Reset counter: 240
Time Indication: 15
Freeze Frame:
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17204000628002000002
VCID: 4487F641C754406443-8010
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 227
Mileage: 131551 km
Time Indication: 0
Date: 2018.05.14
Time: 21:04:32
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J1YG0S4
Coding: 1080004
VCID: 26434CC9912892747D-8072
3 Faults Found:
02203 - Audio / Video Input 1
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 42
Reset counter: 240
Mileage: 126777 km
Time Indication: 0
Date: 2018.02.27
Time: 12:34:57
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
02283 - Video Connection to Output [End Unit]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 55
Reset counter: 219
Mileage: 126847 km
Time Indication: 0
Date: 2018.02.28
Time: 12:38:04
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 210
Mileage: 130638 km
Time Indication: 0
Date: 2018.05.05
Time: 13:07:23
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169AF9560E6C5CC98-8064
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 05:50)--------------------------
- Should I just change out cylinder 4 coil?
- If that doesn't resolve it then cylinder 4 spark plug?
- Should I just change out everything coils & plugs? Spark plugs were changed out 30k ago.
- I've heard that its common to change out coils in Audis and VWs.... common issue with misfiring. Any truth to that?
- Is there a DIY video to do this?
- Looking at the car from the front, which one is cylinder 4 in the engine?
- I often do shopping on Amazon...anyone heard of QYL coils? Reviews got 4 stars from Audi owners.
- 28-HVAC, Rear -- Status: Malfunction 0010
- 42-Door Elect, Driver -- Status: Malfunction 0010
- 46-Central Conv. -- Status: Malfunction 0010
- 5F-Information Electr. -- Status: Malfunction 0010
- 62-Door, Rear Left -- Status: Malfunction 0010
- 6C-Back-up Cam. -- Status: Malfunction 0010
Thanks!!!
Revision: --H07---
2 Faults Found:
7119 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 131891 km
Date: 2018.05.19
Time: 15:29:31
T_AST_ENVD: 0.00 s
P130A 00 [109] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 131891 km
Date: 2018.05.19
Time: 15:29:31
T_AST_ENVD: 0.00 s
Revision: --H08---
Coding: 000002
Revision: 00002001
Coding: 6601207A08
Coding: 0045F7
Coding: 02512B
Coding: 853000
Coding: 020300
Revision: 00000007
Coding: 280106
Coding: 000014
ROD: EV_RBD4K.rod
Coding: 00C1033000
Coding: 00
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 227
Mileage: 130905 km
Date: 2018.05.09
Time: 16:22:34
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 156
Mileage: 124616 km
Time Indication: 0
Date: 2018.01.18
Time: 18:51:13
Coding: 101F00
Coding: 010000
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 143
Mileage: 95643 km
Time Indication: 0
Date: 2016.10.18
Time: 17:40:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Reset counter: 118
Mileage: 95712 km
Time Indication: 0
Date: 2016.10.20
Time: 19:25:30
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 240
Mileage: 129128 km
Time Indication: 0
Date: 2018.04.13
Time: 15:31:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 217
Mileage: 130502 km
Time Indication: 0
Date: 2018.05.04
Time: 14:55:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 217
Mileage: 130502 km
Time Indication: 0
Date: 2018.05.04
Time: 14:55:45
Coding: 030000
H02 0008
Coding: 1E0000
H02 0008
Coding: 1E0000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 66
Reset counter: 240
Time Indication: 15
Freeze Frame:
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 227
Mileage: 131551 km
Time Indication: 0
Date: 2018.05.14
Time: 21:04:32
Coding: 1080004
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 42
Reset counter: 240
Mileage: 126777 km
Time Indication: 0
Date: 2018.02.27
Time: 12:34:57
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 55
Reset counter: 219
Mileage: 126847 km
Time Indication: 0
Date: 2018.02.28
Time: 12:38:04
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 210
Mileage: 130638 km
Time Indication: 0
Date: 2018.05.05
Time: 13:07:23
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
The plugs should be fine. Probably have a bad coil but to test it out swap coils cyl 4 & 5 (If you are in the US cyl #4 is the driver's side bank closest to the font of the car, number five is right behind it). Clear the codes and start it up again. If the misfire moves to #5 replace the coil, if not swap the plugs. If that doesn't work you might need to take it somewhere. Make sure you only change one thing at a time and clear the codes between tries.
Hi
I have had a misfire on my TT RS in the past which VAG scan confirmed was cyl 4 on a 5 cyl engine. So I was thinking it was a coil pack, but I removed the spark plug and found a portion of the ceramic surrounding the center electrode was missing, so the spark was happening inside the plug. Check your plugs first. Cyl 1 should be nearest the fanbelt? Possibly the colour of the plugs will let you know which one was misfiring?
If the plugs look good, then swop the coil packs around and run your engine with VAG scan running, if the misfire moves to another cylinder, then its the coil pack that is faulty. You can do the same with the plugs, though with 30k on them, just renew them.
I was using Denso but have now changed to NGK
Hope this helps
Angus
Hope this helps
Angus
OP, you don’t state which engine, options, year or location.
Swapping the coil 4 with 5 is going to take a while if you only have a 4 cylinder engine. Taking your car to the dealer maybe the last resort if the dealer is 500 miles away and across mud road during the monsoon season. Maybe your APR stage 2 tune has an issue?
Dont expect intelligent answers if you don’t supply any information regarding the big picture.
DB22, you might want to re-read the scan data...Its a 3.0T. Op mentioned changing spark plugs so the engine probably isn't a diesel either.
UPDATE:
So I wanted to get on the road and didn't want to wait for my order to come in. I wanted my car up and running for the long wknd. Since I knew it was a misfire in cylinderDealership and Bosch plug from Pep Boys. Everything is running smoothly again. When I get my parts in in a few days, I'll replace the other 5 cylinders new coils and plugs. Anyone know the size screw for the coil pack harness. I just checked and they're missing. I'm guessing tech never put them in. Sucks.
Thanks everyone for their replies.
S929
10-19-2015 01:38 PM
1999Audi
02-27-2014 11:12 AM
DrewP
08-13-2002 01:07 PM
