Winter Tires - Should I Get a New Set of Wheels, Too?
Hello, I have 20" wheels with summer tires and am debating just buying 20" winter tires and using the same wheels. What are others' thoughts? Is it better to get a set of 18" or 19" wheels and winter tires, or can I get away with buying 20" winter tires, using the same wheels? Thanks in advance.
Over the long haul it's cheaper to get the smallest diameter wheel that can be fitted to your car vs. attempting to swap 2X/yr (and risk the associated damage).
I'd contact Gary over at Tire Rack and get a few suggestions from him.
+1 on that. The idea of letting some doofus put my wheels on a tire machine twice a year makes me cringe. Even at the most careful shop, I'd say you run at least a 25% chance of damage every time you mount or dismount a tire from a rim.
I talked to Damon at Tire Rack who suggested the smallest size wheel you're comfortable with.
This not only protects the wheel during bad weather from impact, but also (usually) is narrower. In effect, the greater weight on smaller contact patches is thought to give you better traction in snow & ice. The downside is that your car probably won't feel as "planted" on dry roads.
Best bet is a set of 18 inch wheels for your A6.
The tires are less expensive. They are easier to mount. You don't cringe as bad when you hit a pothole. Your good wheels are not in the salt and slush.
I won't even mention the cost savings if you plow into a curb...
+2 on this. MUCH easier to have a separate, dedicated set that you can put on yourself, without needing to make an appointment at some shop where there is a chance they'll scratch a wheel. As to your question re: tire size - as others have posted, downsize for snow tires. You'll want more sidewall in the winter to provide more cusion against potholes, and a smaller rim size allows for a taller profile tire so you'll get the extra protection. Also, the selection of snow tires is quite limited in the larger diameters....and expensive. You'll have a much wider assortment and lower cost if you choose 18" wheels and corresponding tires.
Thanks for all the feedback, everyone...very much appreciated! I wanted to mention that I have a wheel and tire package that will repair or replace any damage, scrapes, punctures, etc., with no deductible or additional cost. I don't know if this changes any of your recommendations, but I thought I'd at least mention it. Thanks again!
