Wood Dash center console Bubbling
There a 4 separate bubbles, ranging from 2-4 cm in size under my center console wood where it meets the cup holders. It looks like the wood is lifting. The car in still under Man. warranty. Anything I should be careful not to say when I take it in to get it fixed?
I've had four Audis since 2000, all with walnut trim, and I've never seen or experienced what I see in the pictures. Just judging from your photos, this doesn't look to me like a wear or abuse issue. It looks like the protective top laminate is separating from the wood due to some kind of manf. defect. Although the service dept. might try and quote the 12 month/12K mile warranty "normal wear" limitation, this is not normal and assuming you have the original manf. warranty, it should be covered. If you get some grief, be calm, firm, persistent and if all else fails, call AOA. This shouldn't be happening unless there's something I can't discern from the photos.
It could be that the veneer was applied to a contaminated surface or moisture has expanded the wood and it's lifting along the narrowest surface. If you have to repair it. I would suggest using a hair dryer to heat the area and apply pressure to the area until it's cool.
userbbc
Q5/SQ5 MKII Discussion
38
11-18-2023 10:07 PM
snagitseven
A6 (C7 Platform) Discussion
09-16-2011 02:02 PM
shorty1.8tq
05-30-2004 09:54 AM
