2.0 engine availability in the US
That engine is offered in the much heavier and less aero Q7 and my dealer tells me they go out the door at a much higher rate than the 3.0 Q7’s. In the Q7 the 2.0 goes 0-60 in 7.1 seconds compared to 5.7 for the 3.0. The 2.0 Q7 is also 198 lbs. lighter than the 3.0 version. I am figuring that given the 4,266 lb. curb weight of the 3.0 A6, the 2.0 version would be about 4,068 lbs. curb weight and likely go 0-60 in 6.5 seconds. For many in congested areas this is plenty fast.
I had both the 3.0 and the 2.0 in my pervious A6’s and the 2.0 had a much lighter handling feel, whereas the heavier 3.0 tended to not want to change direction as easily and tended to plow and scrub off a lot of front rubber.
I get the personal preference, but I am just wondering if and when Audi is bringing the 4-cylinder to the US in the A6. My dealer is not sure, but they do know there are many customers waiting for it.
Source: Audi. de C8 A6
Soon, as it has now been released in Germany. Your performance logic was sound, but a bit conservative. The 0-60mph time will be around 0.2 seconds less than the factory 0-100kph time, which is 6 seconds flat. The differences between the two engines will be a bit more obvious in open road / rolling acceleration.
I see your logic for an A6 but not with respect to the Q7. If you drive solo with little goods in a Q7 then you bought the wrong car. Q7 is designed to carry a load and the 3.0 is a must.
I agree. I wouldn't want a Q7 with the 2.0 engine. I was simply using the 2.0 Q7 to show that a big heavy beast can still get out of its own way with the 2.0. I would even say that forthe A6, a typical family with 4 people and luggage would be a bit much for the 2.0. For myself I drive solo nearly 100% of the time and I did find the lighter front load of thee 2.0 made the A6 more nimble feeling when tossing it about.
Pacific Fisher
Q5/SQ5 MKI (8R) Discussion
02-16-2016 10:15 AM
ACSGP
02-01-2006 07:09 PM
VAP
09-21-2005 07:10 AM
mm
10-20-2000 05:57 PM
