Any Vag com mods available for the new A6?
Such as being able to close the boot lid with the key, turn off the safety belt warning and so on?
Hi Hobbe, I've traveled to Gothenburg a couple times. Lovely place....lovely people.
If you have the latest VCDS (Vag com) that works with your car I'd try the instrument cluster module for the seatbelts, same as C7. Just poking around should find something.
9. Disabling seatbelt reminder chimes.
Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
Check this option
[Do It!]
[Select]
[17 - Instruments]
[Coding - 07]
Check this option
[Do It!]
[Select]
[17 - Instruments]
[Coding - 07]
Check this option
[Do It!]
[Select]
[17 - Instruments]
[Coding - 07]
Check this option
[Do It!]
Hi. I tested with the old one to close the boot lid with the key, but it did not look the same. Do you have the instructions for this to send?
Br
Daniel
Br
Daniel
joseaudi
06-28-2008 09:12 PM
joeycuccaro
07-31-2005 02:33 PM
