'02 A6 w/3.0L idles rough, misfires and found low compression
#21
Your best bet is to start a new thread with the coolant leak, this quest for an answer has no relevance to the OP's "Original Poster" thread from five years ago.
#22
Looking at your pics and the gallery photos, looks like headgasket failure.
Now, why it failed is another issue. You could just clean up the block/deck and the head and install another head gasket. I wouldn't be surprised if you need to use new head bolts; the OEM ones are torque-to-yield on most modern engines for uniform clamping force. The surface texture of the head and deck mating areas to the head gasket are critical, not too smooth, not too rough. Helps to check deck and head for flatness as well.
dillon7
01-31-2018 12:17 PM
chirpz
07-21-2014 09:10 AM
vellnueve
09-12-2009 08:00 PM
