1561& 1559 fault code
Old 11-28-2018, 12:01 PM
hamed khodaei's Avatar
Default 1561& 1559 fault code
Hello, my car shows the code 01559 and also the code 01561 but the door is locked& unlock. The flashing light works. I check the wiring and the socket. It's healthy. I do not know where the problem is.
Old 11-28-2018, 12:47 PM
johnkk's Avatar
Sometimes these codes show up when the locks don't all unlock at exactly the same time. I get the code for my rear driver side door because the door unlocks a split second after the rest of the doors. I have ignored it, but perhaps lubricating the mechanism would help.
Old 11-29-2018, 06:22 AM
Thank you for your answer. I try to make a little oil to mechanism
Old 11-29-2018, 07:15 AM
clancy's Avatar
Careful what you use. I used to use graphite but recently read that it is bad. There are lubricants specifically for auto locks.
Old 11-29-2018, 09:25 AM
Thank you very much
Daniel Blackhurst
VAG-COM Discussion
04-22-2013 06:18 AM
audisity
VAG-COM Discussion
09-07-2007 08:42 AM
duct tape
01-09-2004 07:03 PM
BlackouT
04-14-2003 03:01 PM
DAP@EPL
21
07-17-2001 10:19 AM
Quick Reply: 1561& 1559 fault code
