1995.5 urs6 clutch sticking
So I was driving home last night and all of the sudden I pressed the clutch in at a stop sign and the clutch went straight to the floor. It came about an inch off the floor and wouldn't come up unless I pushed it up. I pulled over and shut the car off and let it sit a few minutes, turned it on and nothing changed. So I drove it home like that and parked it. The clutch was still releasing and letting me shift, but it was the whole clutch compressed into an inch instead of about 6. I get paid Tuesday so the shop has to wait until then, but I'm clueless
Thanks in advance!
Thanks in advance!
Try the UR-S forum, but that said, clutches are clutches. I would suspect either:
1. the return spring broke. It is encased in a fiber sleeve adn is visible if you contort yourself upside down under the pedal set. If you pull the clutch pedal up with your toe does it work properly? I drove for ages that way.
2. Clutch slave cylinder is failing or needs bleeding. Bleed it.
Grant
Grant
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
ECS Tuning-Audi
09-30-2015 08:16 AM
ECS Tuning-Audi
09-30-2015 07:47 AM
ECS Tuning-Audi
09-30-2015 06:08 AM
