1999 Audi A6 95k miles Throttle Body Issues P1545
I have a 1999 Audi A6. I was experiencing some problems with it where it would not let me go past 20mph. Recently I had to jump my car several times and I think it was the battery that caused it so I replaced it. But now the car dies suddenly after i start it up. I get a P1545 check engine light code which I know that code points to Throttle Position Controller Malfunction. So I bought a used Throttle Body from the junk yard and that didn't help. I don't know if that was bad also.
I have also tried to do a throttle body adaptation manually but everytime i try to erase the Check engine light code (with my obd II reader) it is still there. I even tried to remove the battery for 30 minutes and it wouldn't remove.
I then turned my key to the on position for 20 minutes and turned the key off and back on....Still nothing...
I am stuck on this...What do you guys suggest?
Also can someone give me instructions on how to do a throttle body adaptation with the VAG-COM?
Thanks!
Thanks!
Isaiah Littlebull (07-29-2020)
I had a similar problem this weekend...
But on my jeep. It threw a code for the throttle position sensor. I dont recall if it is a similar mechanism on the 2.8, but it was a 10 minute DIY to get the thing back up on my jeep v8. Just a sensor that plugged into the side of the throttle body.
As Press said (like usual), search. Your answer is out there.
instructions for TBA from Ross-Tech
<a href="http://www.ross-tech.com/vag-com/cars/throttlebody.html">http://www.ross-tech.com/vag-com/cars/throttlebody.html</a>
Hope that helps...
Hope that helps...
Sometimes you can open up the throttle position sensor area and "adjust" the
spring-fingers of the sensor so they make better contact with the carbon tracks on the ciruit board, if that is indeed the problem. This saved me from having to buy a new throttle body for my VR6 engine.
tcwoods86
17
10-17-2021 11:01 AM
Mark P
10-31-2007 12:33 PM
jb0814@hotmail.com
07-12-2003 10:59 AM
