2.7t power loss after tune
Hey C5 guys, my A6 is running great, but I am hoping to get some ideas of which direction to go in in regards to my early build 2001 6spd. Any direction at all would be a huge help I really appreciate it.
Vehicle currently has 89k miles on it. Bought the car bone stock at 83k miles. Replaced the air filter, DVs changed to 710Ns and ran fuel system cleaner. Car ran perfectly.
At 86k miles I had the ECU flashed to APR stage 1. The difference was unbelievable. Power came on at 2200, at 3200 it would push you back in the seat and at 3900 your head would hit the headrest. Car ran perfectly for about 2 weeks.
About 3 weeks ago I noticed I wasn't getting quite as much power, and especially that the car not longer would "peak" at 3900 rpms. Over the course of the last few weeks, it has seemed to lose that high end extra boost almost to the point where it feels just slightly faster than stock.
No CEL on and vag-con is showing no stored codes at all. Funny thing is, the car runs perfectly fine, its very smooth with no misfires at all, just doesn't seem to be making the same boost and power.I checked all vacuum lines and there doesn't seem to be any leaks anywhere. My brother (who is an ex volvo mechanic) also checked and said the same thing.
I am doing the timing belt in two weekends with a full blauparts kit.
First off, I will also be changing the spark plugs as I have no service history at all on the car, and I am sure they need to be done anyways. Normally I just use the Bosch FR 7 LDC+, but after talking with the shop that tuned the car and reading posts, I was going to go with a plug one temperature lower (any recommendations? Anyone here used NGK PFR6Qs?).
What else would be good to replace/take a look at? Shop that tuned the car recommended I change the MAF sensor (although I have no reason to believe its bad) and the N75 wastegate bypass valves and then see what the car feels like after that and the new plugs.
The issue doesn't seem like the plugs to me. It seems like that car is letting go of boost before it used too. Only other things; It might be in my head, but I feel like the car actually has less power now than even when it was stock below 2200 rpm and I have noticed that sometimes when I start the car cold it idles at 1400 rpm for a few minutes instead of 800, but I am not sure if it did that before.
Thanks.
Kyle
Thanks.
Kyle
Check the program
Do you know how to go through the program on your turn signal stock? If I were you, I would check to make sure the program is still 'set' in your ECU: have you disconnected the battery since the program was installed?
To check, turn your ignition on, but not the car. Hold the cruise control button down on your turn signal stalk until it flashes-one flash = stock tune, 2 flash = your APR tune/or 91 octane tune/ 3 flash = your 93 octane APR tune/ 4 flash = 100 octane-meth injection APR tune. At the program you want to stop at, let go of the cc button and let the car sit for about 60 seconds (ignition on or off, I do off with the key out). Then, turn the ignition back on, but not the car. Make sure the CEL and other code lights are off, then restart. I'm not sure what APR package you got, but I have the 3 program APR package with stock/91/93/100.
My installer said every once in a while if you don't quite feel the 'power' you had before, just do this to check if your program is loaded and you'll be good to go. Otherwise, go hit up your dealer, they should be happy to go over it with you. Good luck!
I have to second rocktown's suggestion - my gf's chipped A4 somehow seems to revert to the stock settings here and there. I don't drive the car much, so it may be something she does and doesn't realize - but it can be something you don't realize right away and then you say think "Whoa, something's not what it used to be".
OrangeMan
07-07-2011 07:05 PM
derekcarmichael
01-06-2007 09:16 PM
RLG
18
12-19-2005 07:05 PM
