Go Back  AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C5 Platform) Discussion
Reload this Page >
2.8 Alternator replacement from underside?
Old 07-11-2018, 09:30 AM
Default 2.8 Alternator replacement from underside?
What are the chances I can pull the alternator from the underside, and bypass the service position completely?
blink is offline
Old 07-11-2018, 11:10 AM
Default Oh God.
Oh God. I'm going to have to do it the proper way huh.
blink is offline
Old 07-11-2018, 11:15 AM
I would say slim to none.
That said, I have sneaked out alternators without going into the service position. First, disconnect the battery. Then, remove the serpentine belt. Then remove the radiator fan (a phillips head screw keeps the bracket in place. Remove the screw and the fan will release from the bracket. Lay it off to one side. Then remove the two bolts holding the alternator in place. One is IIRC 13 mm, and the other an allen bolt 6 mm. With the radiator fan removed, there is just enough room to sneak the allen bolt out. Don't ding the radiator. Loosen the nuts for the electrical connection and the old alternator should be out.
Install of the new one is reverse of the removal. No unusual tricks that I can recall.
As I recall, it took me about 90 minutes to do the job. I guess that I saved about a half hour over the service position.
georgeb944 is offline
Old 07-11-2018, 11:19 AM
Thanks george. I think I'm going to try it. I have a few days until the new alt arrives, just enough time to dread it.
blink is offline
Old 07-11-2018, 01:07 PM
Tech Guru
4Driver4's Avatar
That may work on the 4.2, but on the 2.7 and 2.8 service position is needed. The only way is to slide it out the front.
Consider doing a timing belt service at the same time if it's due soon.
4Driver4 is offline
Old 07-11-2018, 01:25 PM
Is there any way to know which alternator it is before pulling it? There seems to be some conflicting info out there on if the Valeo can be switched with he Bosch.
blink is offline
Old 07-11-2018, 01:28 PM
Tech Guru
4Driver4's Avatar
If the new alternator has the pulley with it, it doesn't matter.
Most likely you have a Valeo.
4Driver4 is offline
Old 07-11-2018, 01:33 PM
Default Woo Hoo!
That's great news! Thanks for your help!
blink is offline
Old 07-12-2018, 04:30 PM
S/RConcepts's Avatar
FWIW, I have removed the alternator on my father's 2.8 Avant without going into service position... same with the starter, actually (did have to lift the engine to sneak that one past the mount). That said, it was an absolute bear to dislodge from it's position, so I'd recommend service position especially if you're unsure when the coolant was changed last. However, it can actually be done with small enough hands.
S/RConcepts is offline
Old 07-22-2018, 01:19 PM
Default An update.
I replaced the alternator today on my A6 C5 with 240,000 miles. I decided to check out how tough it would be to take it out from underneath, assuming I would be resorting to the service position. That was not the case at all. It came out relatively easily if you take your time, and have some degree of mechanical knowledge. I put the car on ramps and pulled the belly pan. From the top side I removed the top engine cover and the electrical fan from right side. I then pulled the 3 pieces of intake routing going to the air box. From the top you can access the nylock nut that hold the retainer that fastens the trans fluid lines to the core support, and at this time remove the 2 mounting bolts for the alternator. (trust me, its not going to fall out.) From underneath you can remove the bolt that mounts the tranny lines to the oil pan, and disconnect the plug on the bottom of the oil pan. Next, unbolt the secondary coolant pump from the bracket, and remove the bracket. I just loosened one side and swung it out of the way, but removing it would have been easier. I was able to work it back and forth to get it to drop, but I've heard of some that are a real bugger to get loose. This is where you take your sweet *** time to get it all the way out. Rotate it to remove the plug and the main power cable. Mine came out with the top of the alternator out first, with the bottom mount up against the secondary coolant bracket, binding it. This is where I pulled the AC lines out of the way with a good bit of convincing, and the alternator was out. I also removed the small wiring bracket that mounts to the motor mount. I hope this helps anyone else attempting this endeavor.
blink is offline
Quick Reply: 2.8 Alternator replacement from underside?
