2000 a4 quattro
2000 a4 quattro
im getting 3 codes from what ive read they all could be from a bad o2 sensor b1s2 open circuit to 12v.imthinking passenger side before cat.codes are p118 p1114 and p1392
Breaking cars for fun.
https://www.audiworld.com/forums/a4-...-discussion-1/
P1114
Bank 1 Sensor 2 Internal Resistance Too Large
P1118
HO2S Heater Control Circuit (Bank 1 Sensor 2)
P1392
Bank 2, Camshaft Position (CMP) = >Sensor 2 -G163- Open Circuit/Short Circuit to B+
quattroworld.com Forums: here's the DTC list off Audi's site although all these may be OBD 2
The O2 sensor codes indicate the post-cat sensor, I'm guessing a wiring problem (broken wire or disconnected), but a bad sensor is likely too.
The P1392 is probably unrelated to the other codes. Not sure which engine you have. If it's the 30 valve 2.8L, I'm pretty sure bank 1 is the passenger side, bank 2 driver side. Bank 2 cam position sensor is on the back of the engine, (bank 1 under the front timing belt cover). If you have the 1.8T there's only 1 bank.
Kahuna-Big
12-18-2009 06:23 PM
4Driver4
17
09-05-2008 03:57 AM
