2000 A6 2.7T Navigation Not Working Nothing Displayed on Information Displayed AirBag Light Wont Era
<center><img src="http://img154.imageshack.us/img154/2569/img4475640x480pe7.jpg"></center><p>
On my 00 A6 that I just got the Navigation system is not working and I also noticed I do not see anything being displayed on the Information Display.
I also also the navigation drive in the trunk does not power up.
Could this be a fuse? Or does it need to be reprogrammed with a vag com?
Also I tried several times to erase my airbag light with a vag-com and it appears to erase but comes back right away. Any ideas on this?
I ran a vag-com and I get this
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 4B0 907 551 L
Component: 2.7l V6/5VT G01 0004
Coding: 06652
Shop #: WSC 40104
1 Fault Found:
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 4B0 927 156 BD
Component: AG5 01V 2.7l5VT USA 3131
Coding: 00002
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
Address 08: Auto HVAC
Controller: รถ4B 082 004
Coding: 00160
Shop #: WSC 02325
Note: Excessive Comm Errors
Address 15: Airbags
Controller: 4B0 959 655 F
Component: Airbag Front+Kopf 1002
Coding: 00306
Shop #: WSC 02325
1 Fault Found:
00588 - Airbag Igniter: Driver Side (N95)
32-00 - Resistance too High
Address 16: Steering wheel
Controller: 4B0 907 487 D
Component: Lenkradelektronik D01
Coding: 00103
Shop #: WSC 65535
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
Address 17: Instruments
Controller: 4B0 920 980 M
Component: C5-KOMBIINSTR. VDO D11
Coding: 02264
Shop #: WSC 00000
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
01311 - Information Data Bus
37-10 - Faulty - Intermittent
Address 35: Centr. Locks
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
7 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01561 - Left Rear Door
59-00 - Can't Unlock
01574 - Alarm triggered by Door Contact Switch: Right Rear
35-00 - -
Address 36: Seat Mem. Drvr
Controller: 4B0 959 760 A
Component: Sitzmemory D05
Address 45: Inter. Monitor
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
1 Fault Found:
01349 - Alarm via Theft Warning System: Front
35-00 - -
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00006
Shop #: WSC 02325
Address 56: Radio
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 02325
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 06652
Shop #: WSC 40104
1 Fault Found:
Coding: 00002
Shop #: WSC 00000
Coding: 0273004284
Shop #: BB 24334
Coding: 00160
Shop #: WSC 02325
Address 15: Airbags
Coding: 00306
Shop #: WSC 02325
1 Fault Found:
Coding: 00103
Shop #: WSC 65535
1 Fault Found:
Coding: 02264
Shop #: WSC 00000
2 Faults Found:
Coding: 15885
Shop #: WSC 02325
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
35-00 - -
Coding: 00101
Shop #: WSC 02325
1 Fault Found:
35-00 - -
Coding: 00006
Shop #: WSC 02325
Address 56: Radio
Coding: 00115
Shop #: WSC 02325
Post this on the VAG forum also.. the Ross guys are helpful.. also check the fuses
and see if you can disconnect Nav module and reconnect it and run the VAG again.. as for your display looks like it has been switched off using the button on the wiper stick.. or it has gone bad.. or some loose connection behind the instrument cluster.. Did this just happen on its own or were you doing something?? Also STFA.. I did a search and found this.. take a look could solve the Airbag issue..<ul><li><a href="https://forums.audiworld.com/vag/msgs/6830.phtml">https://forums.audiworld.com/vag/msgs/6830.phtml</a</li></ul>
AR15Texan
03-07-2017 05:25 AM
TruStylez
04-06-2011 10:24 PM
ROBERTCS
04-16-2009 11:33 AM
upops
VAG-COM Discussion
07-03-2008 10:48 AM
panj
09-03-2004 10:24 AM
