2000 A6 4.2 Brake Caliper leaking after replacement
Old 07-28-2014, 12:30 PM
  #21
ather's Avatar
Originally Posted by SloopJohnB@mac.com
There are many metal washers/seals on the car, among them are the power steering connections at the power steering pump and essentially any banjo bolt-type fluid connections. I've worked on motorcycles and cars for over 50 years…annealing used copper washers is a common solution to reusing them. New ones are the best, but annealing works well.
I just bought new copper ones yesterday. I figured I would give those a try. Thanks very much for the tip though...never knew about annealing.
Cheers,
Ather
Old 07-28-2014, 04:13 PM
  #22
P-Zero's Avatar
Originally Posted by N_Jay
So when someone is having problems, whet do you recommend?
Maybe a few new, proper (not eBay special), washers?
If you use the old washer and it works, great.
But when it doesn't to keep trying is foolish.
If they're having problems, I can guarantee you they're not reusing the original washers. They're using the new cheap crap thin ones that came with the new caliper; which are half as thick as the OE ones.
You mean you don't just "flip them over, and tighten it up real good"? (Smirk)
You never flip them over. You reinstall them in the exact spot they came off of. If you were to flip them over you'd, most likely, have a leak on the ridged side of the washer since it wont go back into the grooves it came out of.
Old 07-28-2014, 08:43 PM
  #23
N_Jay's Avatar
So which was it; the factory reused, or cheap hard copper washers?
(Or no washers?)
FrankS
20
08-26-2021 09:48 PM
goodys90
07-28-2014 07:28 AM
Airbag
11
12-08-2010 09:05 AM
2.7TinCO
18
10-22-2008 09:02 PM
rmrj2184
9
01-05-2008 04:32 PM
Quick Reply: 2000 A6 4.2 Brake Caliper leaking after replacement
