A6 4.2 won't shift out of first.
Old 06-14-2011, 07:50 AM
justinwallace1984's Avatar
Default A6 4.2 won't shift out of first.
I have already tried changing the output speed sensor and the wire harness that runs to it with no luck. Is my transmission bad? Battery was just about dead btw. I think that is where some of the electrical malfunction codes came from.
Address 01: Engine Labels: Redir Fail!
Controller: 4D0 907 558 S
Component: 4.2L V8/5V G 0008
Coding: 06652
Shop #: WSC 24102
3 Faults Found:
18098 - Malfunction Indication Light (K83): Electrical Malfunction
P1690 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-10 - - - Intermittent
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - - Intermittent
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4B0 927 156 BS
Component: AG5 01L 4.2l5V USA 1414
Coding: 00002
Shop #: WSC 00000
2 Faults Found:
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
P0730 - 35-00 - -
17105 - Transmission Output Speed Sensor (G195): Implausible Signal
P0721 - 35-00 --
Old 06-16-2011, 09:24 PM
advancedautomotion's Avatar
Looks like your speed sensor bit the dust change that and that might be your problem!
Did you hit anything? Those trans wires can hang down and get torn up.
Old 06-18-2011, 03:14 PM
It ended up being a broken wire at the connector.
lotus123
Audi 100 / A6 (C4 Platform)
12-21-2023 01:27 PM
ather
01-26-2014 05:55 PM
acrscout
09-30-2010 02:39 PM
leokim27
06-26-2009 10:03 AM
butchieboy
2.7T V6 Discussion
07-15-2008 06:33 AM
Quick Reply: A6 4.2 won't shift out of first.
