2004 Audi A6 Sline 2.7 - Need help with rim size
Greetings from New Jersey!!!
I recently purchased a 2004 Audi A6 Sline 2.7. The rims on the vehicle are some aftermarket brand. It seems like they arent the right size as their may be some rubbing. Does anyone know the original factory rims and tires needed to fit this car and a place to purchase them. Any help is greatly appreciated Thank You! |
I believe 17 x 7 x et 45.
Many 17 and 16" wheels work well, 7-8" wide, and 45-35mm offset. But you can look through the menus on this site (home) and get the data sheet for your car and all the info is in it. Its also in the owners manual, assuming you have that. G |
the original ones are 18 inch, 9 spoke alloy wheels, i think they are called RS6 wheels.
Thx for the help, I found the menu on the homepage with all of the specs for the car, rim size, rotor size etc. Greatly Appreciated!!!!!!!!!!!
18 inch OEM on 2.7? I dont think so....
Maybe some optional upgrade. |
2004 A6 2.7T S-line came with either 17" or 18" wheels from the factory. The choices were 9-spoke 17x7.5" ET43 offset wheels with all-season tires, or 18x8" ET43 offset wheels with summer rubber.
