A6 4.2L Still has no reverse???
#11
ic5 can you tell me who you got your trick valve body from. Thanks. Hows your car doing?
I have an 01 A6 4.2L that lost reverse last year (all forward gears worked fine). It also, shortly after, developed shuddering and torque slam during acceleration as well as through the shift points and started screeching and whining. I have recently rebuilt my transmission using a ZF banner rebuild kit with the F clutch seal and have also had my TC rebuilt. I still have only have partial reverse and the shuddering along with all the same symptoms. It will start out driving fine but develop all the symptoms within 15 minutes of driving. I did not replace the valve body which I now assume may be the culprit, so I have ordered a rebuilt VB from a specialist in CA. Can anyone shed a little light here? Is there anything else I may have overlooked? Much appreciated....Dan
#12
I am having the same issue with my reverse gear. I tried changing the fluid and filter but it still does the same. When it's cold, it doesn't engage as well when the engine is warm. Even it's warm it feels like that you need to rev the engine high to get the reverse going.
I would assume it's the F-piston rather than the valve body? I wanted to do it myself and just worried about getting the car high enough to remove the transmssion as I do not have a car lift.
#13
#14
what was your mecahnic's diagnosis?
most likely it is the transmission. Mine is kind of odd though. Mine works great when cold but slips a little when warm. It wasnt working at all for about a week and then all of a sudden reverse started working again. It still engages slowly but works! I dont get it. I havent even done the fluid and filter yet. Weird!
#15
Hi, I've been out of the country for a while since my last post, sorry I couldn't get to the questions sooner. I've had 3 A6 4.2's and they have all had reverse issues. I beat the crap out of these cars indiscriminately and have successfully tackled every issue you can have with them I assure you all. In one case on my first one, I had replaced the tranny valve body which took care of it. In my second I had replaced the F clutch piston, which had severely deteriorated. The last issue I had that caused me to lose reverse in my current vehicle was the clutch drum that had a hairlike crack in it, I pulled my tranny out and re-rebuilt it 3 times but couldn't find the problem until I pressure tested the drum and found bubbles escaping from it. Replaced the drum and solved my problem. The bottom line is that these are the only areas of the tranny that would cause you to have irregular or total loss of reverse. The F clutch piston is the most obvious source of failure in these units followed by a bad drum and rarely a valve body, although it does happen. Dan
#16
Yea thats what he is saying. But im not going to use this guy as I just found out he screwed another customer on a easy trans rebuild on a suburban. He didnt do crap to the trans except clean it to look like he worked on it. No way im going to give him my hard earned money for nothing.
#17
A8 L Sport 20
12-21-2005 11:03 AM
jcg
9
08-08-2001 03:35 PM
