A6 c5 2.5tdi starting problems
Old 05-27-2019, 09:24 AM
Gaiu Gaiu's Avatar
Default A6 c5 2.5tdi starting problems
Hey guys,i have some starting problems my car,vcds show one mistake,g210 car start but i must turn the key arond 20sek,and then car is starting and works normally,is really can this mistake make this shümptoms?
Old 05-27-2019, 11:27 AM
georgeb944's Avatar
You may have a bad fuel pump.... Or ou may be lower on fuel than the gauge reads... More on this thread here:
Allroad 2.5tdi Low Fuel Level Sensor (G210))
Sale Salac (09-04-2019)
Old 09-04-2019, 11:04 PM
Sale Salac's Avatar
G210 is a fuel level sender located in the small inner housing, which always must have some amount of fuel inside itself. If you have to wait 20secs, that's the time needed for the fuel tank pump to fill that little inner tank with proper amount of fuel. For older cars, if you start the engine before that little fuel housing is filled properly, you will have yellow warning light (coil-shaped) start flashing 25secs after the engine start. This is for the older cars. For your car, you can't start it at all until that inner housing is filled with enough fuel. So, I suppose there is some problem with the inner housing, or electric fuel pump or some hose loose or some gasket leak in there...
CDunham96
New Member Welcome Area
12-09-2017 12:18 PM
MrAvionics
13
06-30-2015 11:31 PM
Fullwell
VAG-COM Discussion
01-20-2014 10:06 AM
GrahamS
9
07-05-2005 11:15 AM
Quick Reply: A6 c5 2.5tdi starting problems
