A6 Headliner Droops
A6 Headliner Droops
After repairing the loose drain hose connection behind the driver side sunroof that caused water leaks in the roof, my headliner near the rear window began drooping. I tried using a hand-held steam gun and narrow fluffy paint roller combination along with the help of a few push pins but that only made the headliner droop wherever I applied steam.
Soooo, I am going to drop the headliner assembly and slide the headliner out the rear of the A6 per Boston Driver’s detailed procedure. Now, how should I repair the droop? I am thinking of putting the headliner on a workbench facing skyward and then somehow use a 3M adhesive spray along with the roller to repair the droopiness. Any tips, timesavers, etc. would be most appreciated.
BTW, I plan on clamping all of the drain hose connections in the sunroof. Are there any other known sunroof issues I should tackle during this surgery?
Drooping a6 headliner
Well, I ended up taking the coward's route and had Tony's Upholstery shop in Edgewater, FL replace the headliner for $200 which included parts and labor. The mechanic said that a6 cars in florida have this drooping headliner problem after a few years and the only way to fix it is to drop the headliner, remove the the old headliner, remove all the glue and then install a new headliner cloth. He let me glue the drain tubes to the fittings which is a very, very important step. He dropped the headliner, then I did the glueing and then he re-installed the headliner with new cloth. I can send pictures of the glueing job if interested - there were 4 glue spots. I used clamps in 2 spots and just glue on th eother 2 spots because the fittings were soft.
I tried the heat gun and roller method which did not work on the a6. Maybe that method works on other car roofs.
I had Tony re-do my headliner 3 months ago and all is well.
05whtaudia6
Auto Detailing Discussion
04-24-2008 06:18 PM
